E30s on 15s - post yours
  • peteb3
    • Nov 2009
    • 157
    #961
    Enkei E92 15x8 with Dunlop 205/55/15
    • bknapp1217@gmail.com
      • Sep 2022
      • 6
      #962
      Just picked up my ‘91 318is this past weekend and am debating between 15 and 16 inch wheels!
      anybody got new pictures to add to this thread!? So much good material in the first 65 pages that I wanted to revive it! Haha
      heres mine on 14” basket weaves!
      • av8drvr
        • 110
        #963
        Here is your twin on 15" Ronal's for perspective.
        • Panici
          • Dec 2009
          • 2396
          #964
          Anybody got new pictures to add to this thread!?
          Nice bump, I've got some good pics!
          15" European Market Basketweave / Euroweave / Style 5
          Bolt Pattern: 4x100
          Width: 7"
          Diameter: 15"
          Offset: ET +24
          Weight: 7.38kg
          Not offered on any North American models. Available as special order from BMW.
          Other Details:
          • Dunlop Direzza DZ102 (205/55r15) Tires
          • Early model (Higher rear arches)
          • H&R Sport Springs (w/ 1/4 inactive coil cut from front)
          • Bilstein Sport Dampers (w/ cut front internal bumpstops)
          • E90 Drop Hats (10-15mm drop in front)
          • 318i Thinner Front Spring Pads (6mm drop)
          • Lemförder E30 M3 Offset Control Arm Bushings (Pushes front wheels forward in the arches)
          First set of pictures (Silver painted car) is 5mm front wheel spacers, 20mm rear wheel spacers.
          Second set of pictures (Brown painted car) is no spacers / stock euroweave offset.
          '87 BMW E30 325is Turbo
          '99 BMW E36 M3 - - - '98 BMW E36 328i
          • treystoys
            • Jun 2022
            • 30
            #965
            15x7.5 35et with a 15mm spacer 195/50 tires
              • Sep 2022
              • 6
              #966
              Stock height?
              • treystoys
                • Jun 2022
                • 30
                #967
                Stock height?
                No, that is H&R sports part # 29664
                • mtech325
                  • May 2008
                  • 566
                  #968
                  Textbook e30 Ronal LS 15x7.5
                  • ube91
                    • May 2021
                    • 46
                    #969
                    Click image for larger version  Name:	DSC099581-min_30.jpg Views:	0 Size:	85.3 KB ID:	10069160
                    15x7 Tire Rack C1Ms. I believe they don't make the sliver ones in E30 fitment anymore.
                    The center caps come off a C3M (also from Tire Rack) and are meant for NA Miatas. In order to get the rear ones to fit, you'll need 5mm spacers in the back.
                    The roundels on the caps simply stick into place. Part number is 36131181082.
                    • Scott540
                      • Oct 2021
                      • 12
                      #970
                      15 enkei 92 Click image for larger version
                      • Panici
                        • Dec 2009
                        • 2396
                        #971
                        Originally posted by Scott540
                        15 enkei 92
                        Looks HOT.
                        That baby blue and gold tho 🥵
                        • Synr
                          • Sep 2021
                          • 31
                          #972
                          what size are the tires? i've got the same wheels in silver, but my tires are small and stretched
                          • OSAH racing
                            • Apr 2022
                            • 244
                            #973
                            Tire rack C 1M 15 x 7, 205/50/15 in gray bronze.
                            • ian e30 318is
                              • Mar 2007
                              • 1809
                              #974
                              Jongbloed 15x10 with a 275/35
                              1991 LS1 Swapped 318is
                              Instagram:
                              https://instagram.com/saltybeast/
                              LS Build Thread:
                              https://www.r3vlimited.com/board/for...s-e30-ls1-swap
                              • Northern
                                I like cupcakes & sh!tboxes
                                • 5223
                                #975
                                Back to 15s for me.
                                225/50R15 R888R
                                Konig Dekagram 15x8 ET25
                                Needs a small spacer up front. May be desirable to have one in the rear, but I need to wind down the suspension to confirm. Ass had to be high with the old setup.
                                Originally posted by priapism
                                Originally posted by shameson
