E30s on 16s - post yours
    Originally posted by AWDBOB View Post
    And this time with a lip and a proper spoiler.
    IMG_2902 by Bobbie Morrone, on Flickr
    Fill and drill or adapters?....looks great!
    1991 318is
    2004 330ci
    2011 335d
      Thanks! Fill/drill. 10mm Spacers front, 15mm rear, 215/45 Azenis tires. Ground Control stock length coilovers.
      1990 Brilliantrot 325iS Build Thread
        Is that the 15" or 16" BBK kit? Spec on wheels and any spacers to clear?
        No spacers they clear the 16" IE BBK
              My sedan on 16x8.5 16x9 RS's
                Put some 16” rollers on while the car is getting the organ transplant.
                Byron
                Leichtbau
                  Does this mean that there is an update coming soon for the build?
                    Clean! Offsets?
                      Originally posted by Mike36 View Post
                      Clean! Offsets?
                      I believe they were 16x8.5 + 9 and 16x9 + 11 if I remember correctly.
                      2.5" Lips front 3" rear.
                        This thread was a big inspiration for me so I have to post my setup too
                        Hartge 5x120 wheels
                        7,5x16 ET13 front
                        8,5x16 ET25 rear
                        currently with
                        205/55/16 and 245/45/16 tires
                        E30 336i S38 Turbo 666kW
                        E30 325iC M50 141 kW
                          (5 Lug)
                          16x8 et11 RS-021 Front with 205/45/16
                          16.8.5 et5 RS-021 Rear (larger lip) with 205/45/16
                          I couldn't wait for my 215s to come in, so installed 205s in the rear for now
                            wow! thats very clean^
                              16x8 et11, 16x9 et11 205/50/16 front, 225/50/16 rear for that moster truck stance rs001 with step up lips/barrels
                                A friend took these shots last year, but I forgot about this thread.
                                Front: 16x8 ET8 ESM 007 / Toyo T1R 225/45R16
                                Rear: 16x9 ET15 ESM 007 / Toyo T1R 245/45R16
                                Rear is a little lower now, had it maxed out during these pics because I had rubbing issues, realized I could lower it another .5" and still be fine-ish.
                                Tires aren't particularly sticky, still get wheelspin in 3rd when the weather is cool. Probably going to switch back to 15s before next year for tire availability.
                                Originally posted by priapism
                                Originally posted by shameson
