E30s on 16s - post yours
    Christ, 245s on the back.
    16s are so hard to get tires for, especially in Canada.
      When I first bought these wheels, a friend was working Saturdays at a dealer and would scope out their tire suppliers to find 225s, often on clearance because they're such a weird size.
      I got a few sets that way, but now my cheapest option seems to be 225 Nankang NS-2 for $180/ea + shipping from PMCtire, or R888Rs from discounttiredirect for ~200/ea plus whatever duty.
      245s seem to be out of the question altogether.
      Only option seems to be to shell out for the 225s in a questionably street legal tire, or bump up to 225/50 (or just run a lighter 15x8 and enjoy cheaper tires)
        I've dabbled looking at JDM tires. A lot more options for 15/16, Never bought anything.
        @Zakspeed_US
          Finally got my 16” TH2s mounted with Pilot Sport AS3+ rubber 16x7 ET25 205/50R16
            16x8 et20 225/45/16 on my old Bronzit 318iA
              16x7.5 et20 e28 m5 (two tone, nogaro center, silver lip)
              Click image for larger version  Name:	IMG_20210426_230143_466.jpg Views:	0 Size:	87.1 KB ID:	10015723
              Alex 88 m5 | 91 318is | 19 Subaru Ascent
              BMW Tool Rentals & Fender Roller
                Originally posted by Northern View Post
                Front: 16x8 ET8 ESM 007 / Toyo T1R 225/45R16
                Rear: 16x9 ET15 ESM 007 / Toyo T1R 245/45R16
                Rear is a little lower now, had it maxed out during these pics because I had rubbing issues, realized I could lower it another .5" and still be fine-ish.
                Tires aren't particularly sticky, still get wheelspin in 3rd when the weather is cool. Probably going to switch back to 15s before next year for tire availability.
                do you have front bbk with this setup?if so , do you needed spacers with this wheels?
                  No BBK (I wish), Stock brakes with brembo blank rotors and pagid OE pads. 325ix booster/master to fit the 24v and I think it has slightly more assist than the stock booster.
                  I run a 12mm spacer up front, the front wheels are actually ET20 and fit without spacers, but my fenders were rolled/pulled before I bought these wheels so I threw some old spacers on to fill the gap.
                    ohh okay , thanks for your answer ! i have read a couple of times your thread but did not remember if you had bbk ! Do the 225s rub with like 3 ppl on the car?
                      Front is fine, but 9" wide ET15 is kind of tight on the rear. Would rub with the 245 for sure with 3 people, but 225 would be fine at this height. Rear arches are rolled pretty heavily though.
                      Edit: The rears rubbed a few times on big bumps with just me in the car yesterday, so not particularly great with 245s (even though these run narrower than most sticky tires)
                        e34 style 5s
                        1993 325iC
                        1998 M3
                        1987 535iS
                          Racing Dynamics RGP 16x7.5 ET25 with 215/45 tires
                          Click image for larger version  Name:	IMG_5168.jpg Views:	0 Size:	73.6 KB ID:	10016797 Click image for larger version  Name:	IMG_5160.jpg Views:	0 Size:	62.4 KB ID:	10016798 Click image for larger version  Name:	IMG_5164.jpg Views:	0 Size:	63.1 KB ID:	10016799
                            The picture is rubbish, but another E30 with style 5's.
                            Sprayed noggy with replica BBS caps modified to fit. Click image for larger version
                            Originally posted by 416stroker
                            well Fünfgang or whatever is the new ubernasty a whore
                              16x8 et16 front. -3deg camber
                              16x8 et0 rear. ~ -1deg camber
                              225/45/16 square Nankang NS-2Rs
ID:	10022864 Style 5s
                                1993 325iC
                                1998 M3
                                1987 535iS
