The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • wazzu70
    • Jan 2005
    • 1143
    #466
    Which value did you change? I'm just now looking at your MSQ and "trigger angle" does not look right. Did you change it to 75deg +45deg addition?
    Can you send me your new MSQ?
    -Nick
    M42 on VEMS
    • Dj Buttchug
      • Jun 2010
      • 7637
      #467
      ^yes amongst other things. Im going to rework my ve tables as well as afr first.
      Things are looking up. Plus the more research/reading about tuning I do the easier understanding all this becomes. cool shit, but VERY technical.
      Turbo M42 Build Thread :Here
      Ig:ryno_pzk
      I like the tuna here.
      Originally posted by lambo
      • Schnitzer318is
        • Jan 2008
        • 2057
        #468
        Ryan, are you running an ICV?
        "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
        91 318is Turbo Sold
        87 325 Daily driver Sold
        06 4.8is X5
        06 Mtec X3
        05 4.4i X5 Sold
        92 325ic Sold & Re-purchased
        90 325i Sold
        97 328is Sold
        01 323ci Sold
        92 325i Sold
        83 528e Totaled
        98 328i Sold
        93 325i Sold
        • Dj Buttchug
          • Jun 2010
          • 7637
          #469
          negative my dude. map only
          Ig:ryno_pzk
          • Schnitzer318is
            • Jan 2008
            • 2057
            #470
            I had long (not hard) starts before adding an ICV. It really helps out, especially with electronics running... A/C, lights, fans, etc.
            Edit: Shoot me a PM with your email address and I'll send you my .msq, I got one of yours finally from Nick and am going to do a comparison. He was asking about my trigger settings though which, honestly, I have never messed with. I got the MS with a tune on it (m42) from DTM and just kept their spark, timing, and trigger settings as they had it. I didn't feel comfortable messing with those.
            I've been tuning injector settings, Ve, AFR targets, ICV, warmup, cold start, etc type settings. Maybe I should look into the other stuff as well.
            91 318is Turbo Sold
            06 4.8is X5
            06 Mtec X3
            05 4.4i X5 Sold
            90 325i Sold
            97 328is Sold
            01 323ci Sold
            92 325i Sold
            83 528e Totaled
            98 328i Sold
            93 325i Sold
            • wazzu70
              • Jan 2005
              • 1143
              #471
              Ryan, can you post up a screen shot of your improved spark settings?
              Im looking at Josephs settings too.
              Anyone out there have a VERIFIED trigger angle? I have verified the 20th tooth after the gap to be TDC. This would be 120deg yet Ryan and Joseph are running 60deg. Would the engine even run being 60deg off on the primary trigger setting?
              -Nick
              M42 on VEMS
              • Dj Buttchug
                • Jun 2010
                • 7637
                #472
                Let me upload and post up again. I know my engine runs set a 60deg. Ive got some time to mess around with it some more.
                wazzu, You are correct. In the settings in order to achieve this you will have to select +45 and then enter a new valve
                Ig:ryno_pzk
                • wazzu70
                  • Jan 2005
                  • 1143
                  #473
                  Here is some trigger info:
                  Typical Vauxhall/Peugeot (and other Bosch) setup
                  60-2 setup is 6deg between teeth (360deg / 60 teeth = 6 deg)
                  Tooth number 20 lines up with sensor at TDC, so tooth 20 to 1 = 19 teeth
                  Therefore 19 teeth x 6deg = 114deg (Tooth #1 Angle)
                  This is exactly our trigger setups since they are Bosch managed 4cyl. Instead of 60 deg, you need to use 114 deg (entered as 69 deg +45 deg).
                  -Nick
                  M42 on VEMS
                  • Good & Tight
                    • Apr 2004
                    • 2057
                    #474
                    You should try tuning with TPS instead of MAP. In "accel enrichment" you can make the changes. Do you have the TPS wired in ...?
                    Need a Turbo manifold? We have them in stock- Click here---> http://rapidspoolindustries.com/
                    ____________________________
                    E-mail Panayiotisx2@gmail.com
                    Dyno vid http://www.youtube.com/watch?v=C7aM7..._order&list=UL
                    • Dj Buttchug
                      • Jun 2010
                      • 7637
                      #475
                      EXCELLENT!!!!
                      Yes
                      This adjustment would be for afterstart correct?
                      Ig:ryno_pzk
                      • Good & Tight
                        • Apr 2004
                        • 2057
                        #476
                        EXCELLENT!!!!
                        Yes
                        Accel enrichment is in the tuning tab at the far right.
                        Are you running on map or tps....? Also have you calibrated your throttle position? Go to tools and you will see calibrate tps.
                        • Dj Buttchug
                          • Jun 2010
                          • 7637
                          #477
                          I calibrated my tps when I first jumped into this. Is it either or? Im confused as to which i am running on...
                          Also for some reason I cannot select a trigger angle valve of 114. It says the value is to high, even when I select +45
                          In order to fix my starting issues I started playing with the very bottom value trim angle (deg)
                          Originally it was set to zero. The value here of +2 made my starts much better.
                          Ig:ryno_pzk
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            #478
                            I'm going to give those cranking settings a shot tomorrow. Mine are the same as yours.
                            If our settings were that far off I'm surprised the car starts... shouldn't not be the case?
                            Edit: Here are my current ignition and wheel settings.
                            91 318is Turbo Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • Good & Tight
                              • Apr 2004
                              • 2057
                              #479
                              Go to the tuning tab and open "Acceleration Wizard" you will see two graphs "MAP Based AE" and "TPS Based AE" right below the TPS graph input put 100 and the MAP Based AE graph will turn of and it will be 100% TPS.
                              Your cold accel enrichment is also in that window, try 130%.
                              For your timing to be accurate you should verify it with a timing light. Not sure if the M42 has timing marks....?
                              • Dj Buttchug
                                • Jun 2010
                                • 7637
                                #480
                                this is what my accel tables look like.
                                Id like to stick with changing one thing at a time if I can. G&T what would these changes you are suggesting do? My map table is faded out here so im assuming TPS is whats running.
                                Also m42 only has TDC mark but the above equation by wazzu is correct because our engines are running a 60-2 wheel.
                                Ig:ryno_pzk
