The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Dj Buttchug
    • Jun 2010
    • 7637
    #496
    Originally posted by Schnitzer318is
    I am going to start a new project and start from scratch with the "correct" trigger/timing settings and go from there. We'll see how it goes. Won't be a for a few days though as it takes forever to build the tune up from scratch using the megamanual as a you go.
    LOL wish I was smarter.
    We are in this together. Im going to have to do the exact same thing it looks like. I cant believe my car made almost 270 whp like this
    Once I get my car idling ill send you my bases
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • wazzu70
      • Jan 2005
      • 1143
      #497
      Well, I would see what some MS experts have to say as to why your car can run decently well being so far off. Your fuel seems really really high to me which leads me to believe its compensating for being injected at the wrong time in the cycle. Your car will run with really retarded ignition, it just will be lethargic.
      I will try and look through both your tunes and send you something that you can test out.
      I have the front of my engine torn down now for repair, so ill snap a picture of the toothed wheel set at TDC so people can see I'm not talking crazy :)
      The M42 gets very little love, so it would be nice to get a solid MS config for people to work up from. Also, my project moves slow, so I can keep busy by getting others sorted out :)
      Maybe one of you can start a thread on the MS forum to get some assistance.
      -Nick
      M42 on VEMS
      • Dj Buttchug
        • Jun 2010
        • 7637
        #498
        I need to know what the stock ignition timing for this engine is. Ive looked all over and all I can find is 8 degrees advance. If this is correct we can use that as a start for settings.
        In other news I marked my teeth up so I can see whats going on while cranking. I might have to plug in my stock ecu, then crank. Who knows. #1 on my list right now is to get the timing dead on.
        Ig:ryno_pzk
        • wazzu70
          • Jan 2005
          • 1143
          #499
          You mean timing advance during cranking?
          I have mine set to 10deg which is a fairly standard setting.
          -Nick
          M42 on VEMS
          • Dj Buttchug
            • Jun 2010
            • 7637
            #500
            yes, I would assume it wouldnt be more than 10 degrees thats why I kind of believe 8.
            If one tooth is 6 degrees (like we established earlier) I should be able to figure out the settings pretty quickly.
            RIP to my super OG snapon timing light. It got run over about a year ago. Sure wish I had it now. I went down and picked up a budget one for 30 bucks at HB. It has good reviews. hopefully it works
            Ig:ryno_pzk
            • wazzu70
              • Jan 2005
              • 1143
              #501
              My timing light is a non-adjustable cheapy. Im sure whatever you got will be just fine!
              -Nick
              M42 on VEMS
              • Schnitzer318is
                • Jan 2008
                • 2057
                #502
                Wish I wasn't remodeling my house... :(
                Have no time for car... maybe when the wife goes back to work next week. She's on mandatory vacation (one week must be taken yearly) and I don't have time for any auto projects with the list of honey-do's she's throwing at me. LOL
                "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                91 318is Turbo Sold
                87 325 Daily driver Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                92 325ic Sold & Re-purchased
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • Dj Buttchug
                  • Jun 2010
                  • 7637
                  #503
                  hah! she must understand all things turbo related must come as first priority!
                  Ig:ryno_pzk
                  • wazzu70
                    • Jan 2005
                    • 1143
                    #504
                    My wife not even let me have tarbo
                    So, I have some good news about trigger settings. I still don't get the MS trigger settings, but you guys had it right. The trigger angle is supposed to stay at 60 and has nothing to do with where tooth #1 is in relation to TDC.
                    You use this spreadsheet to enter the information in the wheel decoder:
                    Look in the manual here under wheel decoder:
                    UltraMegaSquirt, UMS, EFI, Fuel Injection, Auto, automotive, car, TPI, computation, ECU, MegaSquirt
                    Learn something new every day. The documentation in the program could certainly be more clear....but whatever.
                    Sorry for the confusion :loco: Since I led you on a goose chase, I translated some of my tables into things that may be useful for you to try in relation to cranking
                    Crank settings for a 3.2ms req_fuel:
                    Afterstart Enrichment:
                    AFR Targets:
                    Timing:
                    Start with the cranking and afterstart settings and see how that works. If it starts better, then update the AFR table. Use the VE analyser tool to autotune your VE table.
                    If you want to try the timing map, I'd pull a few degrees out of it across the board (take 3 deg or so out) and try that out slowly upping it a degree at a time.
                    -Nick
                    M42 on VEMS
                    • Schnitzer318is
                      • Jan 2008
                      • 2057
                      #505
                      I'll have to go over those settings... I know the spark settings are right but not sure about the decoder ones. Their example is one tooth off mine for a couple of the settings.
                      EDIT: That AFR table is going to be a little rich during cruising won't it? I have my table set so that in cruising the EGO correction is trying to keep it at around 16.
                      91 318is Turbo Sold
                      06 4.8is X5
                      06 Mtec X3
                      05 4.4i X5 Sold
                      90 325i Sold
                      97 328is Sold
                      01 323ci Sold
                      92 325i Sold
                      83 528e Totaled
                      98 328i Sold
                      93 325i Sold
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #506
                        You could choose to lean it out a bit at cruise for slightly better fuel economy if you want. Its not necessary though.
                        It never hurts to double check the trigger settings with a timing light. At least you know you are not way off though now!
                        -Nick
                        M42 on VEMS
                        • Dj Buttchug
                          • Jun 2010
                          • 7637
                          #507
                          wow. Nick you are a boss. way to dig deep for us. Theres a few things im going to try as well. Ill report back and post up whats working. Im out of town over the weekend so it may not be till monday.
                          Nick and Joseph, thank you for all the help!
                          Ig:ryno_pzk
                          • wazzu70
                            • Jan 2005
                            • 1143
                            #508
                            No problem, just trying to learn MS software and help you guys out!
                            I think the cranking and afterstart will make the most difference. Hopefully you can get quick easy starts.
                            -Nick
                            M42 on VEMS
                            • Dj Buttchug
                              • Jun 2010
                              • 7637
                              #509
                              So went back to the 60-2 settings. Something weird to note. My car will start if bump start it every time regardless of engine temp. It can be dead cold and a bump start fires it right up.
                              Any thoughts brahs?
                              Ig:ryno_pzk
                              • LJ851
                                • 7918
                                #510
                                Usually a hard start while cranking is from voltage drop, either a weak battery or a starter circuit that is drawing a lot.
                                Lorin
                                The M30 is God's engine.
