The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • Dj Buttchug
    • Jun 2010
    • 7637
    #541
    Originally posted by LJ851
    Boom!
    Good job. I feel like there should be a sticky somewhere about non OE/OEM crank sensors. No one should be running one !
    Thanks!!
    I know Ive seen that thread somewhere here. I really thought a sensor costing near $100 would be sufficient.
    NEGATIVE lol
    Originally posted by TheTacoMan
    Jolly good, literally pages of trouble shooting for a shit sensor.
    Seriously. Such a waste of time and effort. I was constantly beating my head against a wall.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • Lof8
      • Oct 2006
      • 2827
      #542
      Wheels look sweet! Congrats on finding the issue.
      S50'd
      Originally posted by TDE30
      What is this faggy shit I have happened upon?
      I can always live in a M3. Can't M3 a house.
      • Dj Buttchug
        • Jun 2010
        • 7637
        #543
        Thanks!! :up:
        Also I should add, cranking voltage is now correct @ 12v under starter load. Charging system is perfectly fine!!
        Ig:ryno_pzk
        • LJ851
          • 7918
          #544
          Interesting. My first thought is that the POS CPS was signaling at the incorrect time (early) and putting a much higher load on the starter. Maybe.
          Lorin
          The M30 is God's engine.
          • ccsdo5
            • Mar 2013
            • 707
            #545
            Awesome!! Glad to see it up and running well! This car is such a motivator for mine!
            -Dee
            5-lugged turbo 318is Barn car
            IG: @deebelmont
            • greanthumb
              • 1992
              #546
              Congrats.
              Gratuitous burnout pic?
              91 318is...DD:finger:/85 325es SOLD/91 318is RIP
              Originally posted by naplesE30
              Must stop clicking on Norwegian threads. Makes me wanna punch my car in da mouf.
              Originally posted by einstein57
              My tranny sounds like a blender full of walnuts. So I added sound deadner to the tunnel and put in a louder stereo. Am I doing it right?
              Castro Motorsport/E30 specialist
              North Hollywood, Ca. 818 310-2497
              • Schnitzer318is
                • Jan 2008
                • 2057
                #547
                Nice... big time congrats. Always feels good to solve an issue like that. I still remember pre-boost I had a helluva warm starting/running issue. Turned out to be that the wire in the loom was hooked up for no catalytic converter cars. LOL I just plugged it in during the engine swap thinking it was supposed to be plugged in. It is supposed to be unplugged if you have a cat. That took me almost a year to find.
                Have you done anymore tuning on the car? I was looking at my tune and your req_fuel is not that far off mine. I think mine was 6.0 (calculated by TS req fuel calculator) or something like that. Was curious what you ended up with.
                "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
                91 318is Turbo Sold
                87 325 Daily driver Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                92 325ic Sold & Re-purchased
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • jntar
                  • 459
                  #548
                  Badass! Those Enkei's look like sex.
                  M42 turbo build.
                  http://www.r3vlimited.com/board/showthread.php?t=301330
                  • lambo
                    Captain Scene Points
                    • 10953
                    #549
                    I love the single color 92's!
                    • Dj Buttchug
                      • Jun 2010
                      • 7637
                      #550
                      I have. I did some more yesterday and ive ended up with a req fuel of 6.3
                      Im still working my ve tables a bit because ive got some areas where the engine islean still. Once I get dialed in completely ill post my whole Msq.
                      Ive also got an over cooling issue. I put in a drilled thermostat way back when and its turning out to be a huge mistake. Ill go from 190 down to maybe 150 degrees depending on how much air is moving past the car. Its screwing with my warmup so Im going to swap that out today.
                      thanks for all the comments guys!!
                      Ig:ryno_pzk
                      • wazzu70
                        • Jan 2005
                        • 1143
                        #551
                        Are you using the live VE analyse to sort uot your VE tables? Its the best way by far. When you do this, disable EGO correction. Your fuel map should be really good just after a couple drives.
                        Also what do you mean by drilled thermostat? Where do you drill? I drill an 1/8" hole on the outer rim of the Tstat and put the hole on the top to help with bleeding air from the system. It should not cause any real noticable difference on cooling system function though.
                        -Nick
                        M42 on VEMS
                        • freeride53
                          • 11972
                          #552
                          damn im super feelin the rimz
                          1983 Peugeot 505 STI
                          1992 Volvo 240 Wagon
                          • Dj Buttchug
                            • Jun 2010
                            • 7637
                            #553
                            Im working with the auto tune feature. I drilled my t stat to help with coolant system bleeding. However, I drilled a whole thats pretty big. My car will heat up at a stand still but driving on the freeway my temp drops back down to 155 ish. I drilled right around the rim probably just like you did.
                            I also had an 88 C stat to begin with. I want a more stable operating temp so I can tune properly.
                            Ig:ryno_pzk
                            • wazzu70
                              • Jan 2005
                              • 1143
                              #554
                              Well it certainly cant hurt to replace the Tstat with another and see if it solves your problem. Hopefully it does the trick.
                              Im definitely not at 65c on the freeway.
                              -Nick
                              M42 on VEMS
                              • Dj Buttchug
                                • Jun 2010
                                • 7637
                                #555
                                its not really thats its a problem its just kind of annoying. It still runs well but from stop and go my temp fluctuates so much. My cluster temp gauge reads just above the cold mark when at speed. I can watch in drop down lol
                                Ig:ryno_pzk
