The 15 Y/O Turbo M42 Build Thread (Now Holley EFI Terminator X Controlled)
  • 2mAn
    Señior Mod
    • 20345
    #811
    Dang, thats a legit number! Nice... Would love to see the graph
    Simon
    Current Cars:
    -1966 Lotus Elan
    -1986 German Car
    -2006 Volkswagen Jetta TDI
    Make R3V Great Again -2020
    • ccsdo5
      • Mar 2013
      • 707
      #812
      Hell yeah! still one of my favorite cars to this day looks and engine. Glad to see a 3 as the starting number haha!
      -Dee
      5-lugged turbo 318is Barn car
      IG: @deebelmont
      • Dj Buttchug
        • Jun 2010
        • 7648
        #813
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • Dj Buttchug
          • Jun 2010
          • 7648
          #814
          Turned out well overall. I was very conservative on the redline just to be easier on my engine. There is more hp there if I add some more boost and pull a little more time. It was also a bit warmer, so on cooler days I anticipate a little better numbers. As of now I am content with the results and will likely leave it alone. The car is a blast to drive and I am still using a G240 trans. Reliability has always been a big concern so I think leaving the engine as it sits now is a good balance between power output and longevity. Yes the internals can take more. In my mind its not really worth it. The car rips as it is. We did do a final 4th gear pull and I managed to munch a spark plug. Melted a strap and blew the insulator off the electrode. Misfire started at around 4k on cylinder three. Here is the result.
          Swapped out the whole set of plugs and luckily things are ok. I was worried the pieces of insulator could have damaged my engine but after a borescope was done no damage was found. Butt pucker scenario for sure.
          Now time to focus on the M50 engine for my E34. If anyone has questions about Holley EFI or the process in doing this let me know. For now its time to put some miles on the car and enjoy it.
          Ig:ryno_pzk
          • econti
            • May 2014
            • 1119
            #815
            Greasy torque curve. How many pisseye?
            • Dj Buttchug
              • Jun 2010
              • 7648
              #816
              17.4 pisseyes
              Ig:ryno_pzk
              • Northern
                • 5168
                #817
                I would've shit a brick at the sight of that plug
                Originally posted by priapism
                Originally posted by shameson
                • econti
                  • May 2014
                  • 1119
                  #818
                  Originally posted by Dj Buttchug
                  17.4 pisseyes
                  Barely even breathing. Nice result
                  • zwill23
                    • Jul 2015
                    • 615
                    #819
                    I really think 300whp is the perfect amount for this chassis, with the right setup everything is well balanced and it's not a burnout machine. I've opted to not push the pisseyes as well and I think it's the only reason the engine is still together 30k miles later. M20 but same philosophy.
                    • Dj Buttchug
                      • Jun 2010
                      • 7648
                      #820
                      Do you see it.
                      Ig:ryno_pzk
                      • econti
                        • May 2014
                        • 1119
                        #821
                        Shit go. What from?
                        • Dj Buttchug
                          • Jun 2010
                          • 7648
                          #822
                          Shit go. What from?
                          A while back I dyno tuned the engine and cylinder 3 spark plug failed at about 5k rpm under 15psi. The insulator broke off inside the combustion chamber. The gouges in the cylinder head outer area are the result of that. I was unable to see this when I borescoped the cylinder. I cannot confirm this same event caused the cylinder head to crack but it is possible.
                          My #3 piston is also a bit beat up.
                          New OEM old stock m42 cylinder head from Germany via Turner Motorsport. $2,900.00
                          New CP piston set at a discounted rate due to the sales rep feeling bad for my situation $800 shipped.
                          85mm ball hone to revive the cross hatching in all cylinders after 10 years of incorrect overfueling/megasquirt love and care $116
                          Expensive Lesson.
                          Only use REAL (not fake chinese copies) NGK spark plugs. Failed plugs were DENSO brand. The only real surprising thing here was the cylinder HG and cracked head has lasted almost 2500 miles of everyday driving until it finally gave up resulting in a constant misfire on #3 due to coolant intrusion and cylinder head crack between valves.
                          The 318 is gonna be down for about a month or so until the parts arrive.
                          Fun right?
                          Ig:ryno_pzk
                          • econti
                            • May 2014
                            • 1119
                            #823
                            I would doubt the crack is from that. I think most likely from high exhaust temps, or over tightened head studs but I wouldn't expect that mistake.
                            Could also just be one of those things on an old motor, maybe it was overheated before your time.
                            Such is the game for more than doubling the power out of old engines. Doesn't make it any cheaper however.
                            • Northern
                              • 5168
                              #824
                              I think the same crack issue happens on the 24v stuff. Not common but not super rare. Seems mostly random
                              • 2mAn
                                Señior Mod
                                • 20345
                                #825
                                No luck on the WTB here? Bummer...
                                Simon
                                Current Cars:
                                -1966 Lotus Elan
                                -1986 German Car
