Danny's 4door Calypso 24v car
  • Danny
    • 14216
    #481
    Indeed, so he's going to check the timing and go from there.
    • Danny
      • 14216
      #482
      Popped through the intake if I threw starter fluid at it.
      • 416stroker
        • May 2008
        • 2448
        #483
        Well I hope its nothing internal.
        84 318I Delphin RIP
        87 325IS delphin 24v Sold
        89 325 Alpineweiss
        • Danny
          • 14216
          #484
          Me too, although I don't think it is. Compression was even.
          • 416stroker
            • May 2008
            • 2448
            #485
            Thats good.
            84 318I Delphin RIP
            89 325 Alpineweiss
            • Wh33lhop
              • 11705
              #486
              Originally posted by Danny
              Yeah I will, Adrian's best guess is that the bolt that actuates the VANOS slipped and caused the intake cam to advance too far forward, effectively screwing up the timing.
              Did you rebuild the VANOS since I last heard it diesel status in the silver car?
              paint sucks
              • Danny
                • 14216
                #487
                No I didn't but that wasn't the VANOS, it was loose spark plugs. Yes, seriously.
                • Wh33lhop
                  • 11705
                  #488
                  wat
                  paint sucks
                  • LJ851
                    • 7919
                    #489
                    Equally bent valves. Haha! Just kidding. I called Vanos failure a couple pages back, we'll see if i'm right.
                    Lorin
                    The M30 is God's engine.
                    • Danny
                      • 14216
                      #490
                      How many internets would you like to wager, sir?
                      • LJ851
                        • 7919
                        #491
                        There are only 2 ways to affect cranking compression, Damage to a sealing surface or cam timing. You did have the throttle wide open while you were testing compression, right? I'm going hold my wager because the compression #s going up that much with oil dont add up to me, assuming the test was done right.
                        Lorin
                        • Danny
                          • 14216
                          #492
                          Keep in mind that I had been cranking the motor with fuel spraying for over 12 hours. The cylinder walls were washed down with fuel.
                          • LJ851
                            • 7919
                            #493
                            ^ Your poor starter, that thing deserves a medal!
                            Lorin
                            • Danny
                              • 14216
                              #494
                              Yeah it does, its a real trooper!
                              • LJ851
                                • 7919
                                #495
                                Whats the story? I've been awake for almost an hour now, you west coast guys sure take your time gettin to work.
                                Lorin
