Danny's 4door Calypso 24v car
  • Danny
    • 14216
    #451
    Fuel pressure is still solid at 50psi while cranking.
    • KenC
      King of Kegstands
      • 14396
      #452
      Apology for not reading the whole thing.
      180 out of timing?
      Originally posted by Gruelius
        • 37832
        #453
        I left those loose on my car and it caused issues. To clarify yes I am talking about the two nuts that hold the injector wiring to the fuel rail.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • theryp
          • Jul 2010
          • 38
          #454
          :) me gusta
          http://www.flickr.com/photos/theryp/
          :p
          • LJ851
            • 7919
            #455
            does that thing have a cam sensor? If you have spark and fuel, time is all you are missing although your dry compression #s are pretty low. Vanos failure?
            Lorin
            The M30 is God's engine.
            • ck_taft325is
              • Sep 2007
              • 6880
              #456
              Super true. Had an "experience" with this right after the S50 was running.
              Need a part? PM me.
              • stinkydriverx
                • Jan 2008
                • 501
                #457
                sounds like timing.
                its probably something simple. Just like everyone else is saying, go through with a multi meter.
                Turbo m30 drift car build.
                500whp or bust.
                http://www.r3vlimited.com/board/showthread.php?t=256525
                • trackjunkie21
                  • Jan 2010
                  • 3962
                  #458
                  How can it be timing if it ran PERFECTLY before? I'm 100% doubting it being out 180*. My bets are on CPS, even though there is spark and fuel.
                  Originally posted by Wh33lhop
                  VANOS: sometimes you just need to go full retard.
                  • Danny
                    • 14216
                    #459
                    180 out of timing?
                    Unless I jumped a tooth or something I highly doubtt it. The car was running perfectly two days ago.
                    Issues like not starting? Seems strange.
                    Originally posted by theryp
                    :) me gusta
                    Thanks man.
                    It ddoes indeed, you think its bad maybe?
                    Do tell.
                    Originally posted by stinkydriverx
                    sounds like timing.
                    Timing thrown out after the car was already running perfect?
                    Cps seems suspect. If I take a MM to it it should ohm to high 500s during cranking?
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      #460
                      It's obvious its a signal/ground issue. That's why I said start with pinning out. Coulda found the issue yesterday.
                      Muchlub<3dannyboi!
                      • Danny
                        • 14216
                        #461
                        How do I start pinning out? I know nothing of etms or wiring.
                        • Farbin Kaiber
                          Lil' Puppet
                          • 29502
                          #462
                          A powerprobe would be your best friend right now. They also have a sender kit to tone across long runs but I would start with the millimeter on required signal sensors to start, then start tracing the harness out if you don't find anything. Do you have an e36 Bentley manual?
                          • LJ851
                            • 7919
                            #463
                            Danny, you need to learn to FLEX like Farbin. That E30 of yours will get the picture RIGHT AWAY and start walking the line. It wants to be good but i think you need to establish dominance. You are the alpha in this relationship, right?
                            Lorin
                            • Danny
                              • 14216
                              #464
                              Right.
                              Now what signals are required for starting? CPS cam coil packs ECU?
                              • Danny
                                • 14216
                                #465
                                Right.
