Danny's 4door Calypso 24v car
  • lolcantturn
    • 4588
    #466
    Originally posted by Danny
    Right.
    Now what signals are required for starting? CPS cam coil packs ECU?
    Yes.
    Take a look at your CPS. It's not uncommon for it to randomly come loose. Ohm that bitch out also
    Originally posted by TSI
    OEM+
    • Jean
      • 18228
      #467
      Ohm the CPS yet? Is it running yet?
      • Ryann
        • 3350
        #468
        Ohms test on position sensors? You guys are nuts. If he's to test his crank/cam sensors he'll be probing for ac voltage.
        • Jean
          • 18228
          #469
          I am pretty sure they are talking about at least ohming the cps.....
          • Ryann
            • 3350
            #470
            Typical mode of failure for a position sensor is loss of signal vs. internal short in my experience.
            • Adrian_Visser
              • Jun 2006
              • 2823
              #471
              Loss of signal is usually caused by change in internal resistance of the sensor i.e. checking resistance with power off is an easy way to check the integrity of the sensor. Should be around 540ohms on the CPS. But I don't think that's your problem. If your plugs are indeed wet the engine may be flooding out right away that would explain why it tries to start for a second then won't do anything. If it isn't the DME maybe there is a short to ground in the harness somewhere in the ground side of the injector wiring harness (keep in mind that the DME controls the fuel injectors by switching ground to them).
              '89 Alpine S52 with goodies
              • LJ851
                • 7919
                #472
                Ohm testing a CPS is worthwhile, however i have seen more than one Ohm correctly and not function . AC voltage while cranking proves the sensor is working as Ryann mentioned.
                Lorin
                The M30 is God's engine.
                • Danny
                  • 14216
                  #473
                  Welll its in God's hands now. And by God I mean Adrian and by hands I mean M service garage.
                  • 416stroker
                    • May 2008
                    • 2448
                    #474
                    my guess is cam or crank sensor
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • Danny
                      • 14216
                      #475
                      Go ahead and guess all you want, out of my hands now.
                      • 416stroker
                        • May 2008
                        • 2448
                        #476
                        I know. You gonna post what was wrong with it when you find out?
                        84 318I Delphin RIP
                        89 325 Alpineweiss
                        • Jand3rson
                          • 37587
                          #477
                          Nothing wrong with that, when there's just something you can't or don't want to figure out, pay someone that does.
                          • Danny
                            • 14216
                            #478
                            Yeah I will, Adrian's best guess is that the bolt that actuates the VANOS slipped and caused the intake cam to advance too far forward, effectively screwing up the timing.
                            • 416stroker
                              • May 2008
                              • 2448
                              #479
                              Damn that would be crazy if that happens
                              84 318I Delphin RIP
                              89 325 Alpineweiss
                              • Jand3rson
                                • 37587
                                #480
                                A theory! At least that's something!
