Danny's 4door Calypso 24v car
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #436
    I'm feeling ground, or broken wire in harness or sensor. I feel like I always say this on 24v no start threads, but start with the multimeter and check sensors first, then continuity from sensor connector to DME connector.
    • Danny
      • 14216
      #437
      Originally posted by Jean
      So what was the fuel issue you fixed?
      No 12v to the fuel pump, fixed it by removing the aftermarket alarm.
      But it has already been running and I checked all the grounds. All the important wires to start are connected.
      • Dj Buttchug
        • Jun 2010
        • 7688
        #438
        maybe its vapor locked?
        edit nvrmnd. ninja post
        Turbo M42 Build Thread :Here
        Ig:ryno_pzk
        I like the tuna here.
        Originally posted by lambo
        • AndrewBird
          The Mad Scientist
          • 11898
          #439
          When you removed the alarm, are you sure you got everything hooked up back as if it were never there? Maybe there is a wire not connected somewhere.
          • 87e30
            • Jul 2008
            • 5676
            #440
            I'm assuming you've felt under the IM for all the sensors... like that annoying one next to the fuel lines on the underside of the intake manifold...
            Shit I hate these little things.
            I just hate everyone.
            No need for discretion.
            • Danny
              • 14216
              #441
              Okay I changed the oil and changed the spark plugs and tried again.
              Same symptoms. I get a 1281 code which could mean my DME is under powered? I get the code with the red label 413 versus the 506 silver. I'm so beyond stumped on this.
              • Danny
                • 14216
                #442
                Here's a video of it cranking, you can hear it almost wanting to pop over.
                • LJ851
                  • 7919
                  #443
                  That is not wanting to start, that is a misfire.Hear how it slows the cranking like its getting punched in the stomach? Did you try starting it on ether? Are your plugs wet with fuel when you pull them out? If you are getting fuel and the engine is not starting the plugs should be wet. What does your crank sensor look like? any damage to it or to its wire all the way back to the harness? Is the sensor gap correct?
                  Lorin
                  The M30 is God's engine.
                  • Jand3rson
                    • 37587
                    #444
                    I didn't see if this was mentioned already or not, but have you tried another ECU?
                    • Stephen
                      Шлем ишака
                      • 10774
                      #445
                      Danny, get that shit fixed so you can come up for the picnic and then help me with my headswap after. namsayin
                      • Ryann
                        • 3350
                        #446
                        The popping in the vid sounds like either unmetered air or shitty spark timing to me.
                        • Danny
                          • 14216
                          #447
                          Yeah I tried on starting fluid and it backfired through the intake. Plugs are wet indeed. Wet with fuel. Sensor looks okay, the gap is the same as its always been, its tight in its holder.
                          Yes indeed. No change.
                          Its a backfire type sound through the muffler.
                            • 37833
                            #448
                            This seems stupid but see if the 2 10mm nuts holding the injector wiring on are tight.
                            Grover Beach, California
                            BimmerHeads.com
                            • Danny
                              • 14216
                              #449
                              The two nuts that hold the fuel rail to the injector harness? Those have always been missing, never been an issue.
                              • 416stroker
                                • May 2008
                                • 2448
                                #450
                                weak fuel pressure? Just enough to make it pop maybe thats all?
                                84 318I Delphin RIP
                                87 325IS delphin 24v Sold
                                89 325 Alpineweiss
