Abit's 318iA m20b30 + pssycat cam and more...
  • gath
    • 577
    #286
    and of course...first start video
    coils was not fully plugged on, so engine was not working as it should,
    later fixed that problem
    Nice! :grin:
    • digger
      • Nov 2005
      • 6196
      #287
      There's isn't enough thread engagement IMO for cast iron with that bolt. You also don't really need 90Nm oiled. ARP are 95Nm with studs that go deep and they only pull up they dont impart torsion into the block
      • abit
        • Jul 2011
        • 423
        #288
        I agree, seems like oem bolts don't go deep in tread :roll:
        So you say that i'm torquing head bolts too much?
        but I always torqued them to these nm, with oiled thread.
        I will try to make thread deeper in block (in bolt hole its not till end) and try to torque it with stud-nut, if it holds, for this season it will be ok, I don't want to take off head already
        http://instagram.com/mundieriss
        my 88' m20b30 HERE!
        • digger
          • Nov 2005
          • 6196
          #289
          those are not current OE m20 head bolts which are torx head
          https://www.ecstuning.com/b-genuine-...t/11121726478/
          OE bolts are not torque to 90Nm it is a torque and angle method.
          they should go much deeper into the block
          BMW general recommendation for M10x1.5 12.9gr is 80Nm
          for OE torx bolts it is 30Nm + 90* + 90*
          • abit
            • Jul 2011
            • 423
            #290
            soooo
            head bolt ''issue'' was repaired in fast way;D:D
            made thread further inside bore
            spec tool :D
            and final result, seems like It will hold :D
            next, changed thermostat, made 5 holes in thermostat for better bleeding
            after that car wont heat up, max I reached was lil bit over blue sector :D
            second try, made 3 holes, It stayed better but still, wont heat up propertly, it reached normal temp standing, but, when you started to drive it cooled down to middle mark..
            so I taped radiator, and it helped :D
            on highway its ok, but it wants to start boiling in traffic jams
            yesterday found out that fan clutch is completely down, fan is spinning freely, will replace that, maybe something will change...
            and then It was time for remapping ecu
            garages owner car, twin turbo e36 m50BXX, about 700 or so hp as I remember..
            everything was good and promising, m20 goes like never before
            but then next day it started to misfire on full load on 1st and 2nd gear at about 4k rpms, when the vtec kicks in :D
            on other gears it was ok so, decided that I should check ignition system, because I knew, that I should change spark plugs anyway.
            as forum members recommended, bought BPR6ES plugs, before that I used WR7DP bosch plugs
            I checked ignition system, after that 1 coil and 1 spark plug socket
            and now everything goes like It should....but clutch isn't :D
            maybe someone can suggest something about clutch?
            it wants to slip kicking in 3rd gear..can't do smokey burnouts :D
            THATS ALL FOLKS!
            my 88' m20b30 HERE!
            • abit
              • Jul 2011
              • 423
              #291
              Soo, car is running, and seems like it goes pretty ok ;D:D
              Participated in local forum track day, have to say, car delivers power really nice.
              on some semi slicks
              and of course some doriftoo :D
              at track I could slide in 3rd gear, actually had no clutch slip...seems like tires slipped easier than clutch
              stance is life
              and some burnouts too..
              ok, Its enough, nothing more interesting done.
              hoping to get to dyno asap
              ...because DTM Warsteiner
              my 88' m20b30 HERE!
              • abit
                • Jul 2011
                • 423
                #292
                well..
                since last time, when I drove this car properly, I realized that engine mounts are too soft. so bought poly m50 eccentric engine mounts and e21 gearbox mountings(bit bigger/stiffer).
                sittin on e21 mounts
                engine mounts
                also changed front windshield, sooo nice ;D:D
                aaalso cars outside look changed a bit, changed lip to old one, no more race car :( aaand roof rack off
                bye bye
                now
                also thinking about lip from e36 mtech bumper
                that's all for now
                my 88' m20b30 HERE!
                • gath
                  • 577
                  #293
                  Did you get the dyno numbers yet?
                  • abit
                    • Jul 2011
                    • 423
                    #294
                    Unfortunately the car is still not dynoed :(
                    BUT!
                    I have some fresh shots :D
                    my 88' m20b30 HERE!
                    • gath
                      • 577
                      #295
                      Looking good ;D
                      • wworm
                        • Dec 2016
                        • 1719
                        #296
                        Originally posted by abit
                        bought some stuff
                        noob q: what wheels are these?
                        1984 Delphin 318i 2 door
                        • abit
                          • Jul 2011
                          • 423
                          #297
                          schmidt revolution modern line, these were 15'' 8J ?
                          aaand there is some acceleration video of my 3.0
                          my 88' m20b30 HERE!
                          • hasa
                            • May 2013
                            • 307
                            #298
                            Here is something I don't understand. How can this work ?
                            • sampayne
                              • Apr 2014
                              • 396
                              #299
                              Originally posted by 2mAn
                              The BMW V6 is the best
                              • jeenyus
                                • Aug 2011
                                • 2064
                                #300
                                now that you say that.... i'm wondering the same thing.
