Another m30e30 & a new project
  • rzerob
    • Jun 2013
    • 2315
    #136
    Originally posted by Anthony B
    yeah it’s not a great looking pool queue, the hood shock works perfectly unfortunately there was a 60km/h headwind that slammed the hood shut. I have the queue as my boot lid prop
    If that is a pool que then it is an easy fix. A little sanding and stain.
    • lukeADE335i
      • Apr 2013
      • 1389
      #137
      Hi Anthony
      Thought I'd bump your thread and see whether your car is up and running now? So close!
      Hopefully you're not caught up in fires. If you are, stay safe.
      Cheers
      Luke
      My e30: OEM+ with M30B35
      • Anthony B
        • Nov 2012
        • 308
        #138
        Originally posted by lukeADE335i
        Hi Anthony
        Cheers
        Luke
        thanks for checking in mate, fires have gotten really close & still on a watch & act alert where the car is kept.
        Still yet to run have been chasing shadows trying to get a replacement alternator which thankfully I acquired last night. Also was put on a “no more money on the car” by the now wife while we sorted the last of the wedding. But wedding is wrapped up we’re now hitched, I’m hoarding dollars for the ecu & waiting for my fabricator to return to work eta end of Jan of the stars align
        • lukeADE335i
          • Apr 2013
          • 1389
          #139
          Good to hear all's ok - and congratulations on getting hitched! Life must take priority over cars :)
          • LowR3V'in
            • 4209
            #140
            still can't wait for the dyno
            • lukeADE335i
              • Apr 2013
              • 1389
              #141
              Hi Anthony
              Just thought I'd bump your thread and check in to see how you're going? I'm presuming that COVID-19 has put a dent in finishing off the car, but I hope all is well!
              I've been chipping away at a few small niggling issues on my car with it sitting around a lot more than in the past - it's back to running well again. About to drop the radiator to do a full ignition service (new cap, rotor, coil & plugs) seeing as the cap and rotor have done 100,000km since I did my swap! It's a pain having to pull the radiator to swap the distributor cap... maybe wasted spark is the way forward :)
              Cheers
              Luke
              • Anthony B
                • Nov 2012
                • 308
                #142
                Hey Luke
                Covid has made work mental (I work in superannuation) but I’ve taken a much needed holiday & it’s been full steam ahead on the e30. Picked up the ECU on Thursday, cars booked in on the 30th of Sep for the exhaust & we should be firing it up.
                wow a 100k since your swap‽ that’s the definition of a solid swap, I wish I got to enjoy that many km’s out of mine before I broke it.
                I’ve been lazy uploading photos to Flickr to post here, but if you’re on insta I upload heaps there “@antb_e30” but I’ll do a photo update here soon
                Cheers
                Ant
                • Anthony B
                  • Nov 2012
                  • 308
                  #143
                  So here’s a bit of a photo dump since the whole COVID fiasco I’ve struggled to spend time on the old iPad to upload photos. Since the last update I decided that I needed to 5stud swap the car.... this didn’t help me finishing the engine side because I have poor self control
                  Untitled by Ant Bolic, on Flickr
                  I also made my own front swaybar linkages machining up some spacers to use the Ireland engineering e30 ones I had
                  & currently waiting on these to ship over from Japan - American racing 3 piece 17x9.5 +34 so will be getting resized
                  The ECUmaster classic has its new home, I just need to load the base map
                  Currently just awaiting the exhaust to be fabricated which is booked in for the 30th of this month,
                  • lukeADE335i
                    • Apr 2013
                    • 1389
                    #144
                    Nice update there Ant! Good to see the car will be running around the end of the month. Exciting times. In superannuation you must have been really flat out the last few months.
                    Have you had a wheel alignment done with the SRS concept lollypops? (I checked out your insta thread) I had been thinking of ordering some for a while, but thought I'd wait for someone else to try them first to see whether they work as advertised.
                    I took mine for a long run tonight and it's back to 100% with the new ignition stuff installed.
                    • Anthony B
                      • Nov 2012
                      • 308
                      #145
                      Yeah the super industry has been nuts since March glad I’ve finally got a break away for a few weeks.
                      yet to do an alignment, caster wise they are spot on visually I’ve just got to adjust the toe angle as the front right is about 6-10 degrees out.
                      I’m hoping the fire up goes smoothly cause I’m itching to take the car out for a blip
                      • Anthony B
                        • Nov 2012
                        • 308
                        #146
                        So a bit of an update... the car now runs
                        On the way to my fabricators to knock the exhaust out
                        • Anthony B
                          • Nov 2012
                          • 308
                          #147
                          Going back for another dyno run after a trackday this coming weekend, the torque figures where/are lower than expected
                          not sure if its just a dyno dynamic being a heartbreaker as per standard, but there was a loud howl from the dyno which wasn't normal, but I also have a handbrake to adjust as it was dragging through the dyno runs. The butt dyno is well impressed by the current experience, this coming weekend is a 1.3km tight handling circuit which should let me get a proper shakedown & let me tweak the new suspension setup.
                          The runners are going to get changed out for some non-tapered runners, currently they are 48 to 45mm. Rama from RHD has a few ideas on how to squeeze some more power out.
                          Other jobs to tackle are plumbing in a 4kg extinguisher, fitting the 1/2 cage, harnesses, & changing the 3.15 diff out for a 3.46
                          • digger
                            • Nov 2005
                            • 6196
                            #148
                            The rpm scaling looks wrong probably why torque seems low
                            • digger
                              • Nov 2005
                              • 6196
                              #149
                              Personally i think you're going to end up changing that cam, ported head and 9.5mm lift don't go together that great with a single 47mm (or whatever) inlet valve, the valve never gets out of the way to use the port effectively its always using the curtain area. You want the most lift you can physically while keeping duration minimized to get the L/D up you're at 0.20 now. The M30 is kinda hamstrung with the rocker ratio but seems to be some better profiles around with 11-12mm lift possible with cam sub 300 advertised tight LSA.
                              i would go straight to https://www.millerperformancecars.co...amshaft-detail these are Paul burke cams who knows his stuff from an engine combo perspective and is not just someone who knows how to grind cams which is what most grinders are.
                              Rama would know about franklin cams http://camshafts.co.nz/bmw.aspx (ask for m30 profiles)
                              • Anthony B
                                • Nov 2012
                                • 308
                                #150
                                Very much looking at a bigger lift cam, Rama & I both discussed it being a limiting factor currently. To go to a higher lift I need to swap out to a steel rockers to get the benefit of the longer lash pad.
                                This is the cam chart to the current one http://www.catcams.com/products/cams...nguage=english
                                I’ve got my eye on the PPF offering http://server.pure-pf.com/webshop2/e...1-m30-z55.html
                                along with these https://kmcams.com/products/bmw-m30-...el-rocker-arms
