Another m30e30 & a new project
  • digger
    • Nov 2005
    • 6196
    #121
    interesting idea with the electric WP, on an M20 it would help with fitment of an ATI style damper for the bigger crank engines to allow them to be wound up for extended periods of time. ATI dont have an M20 damper solution that retains the 3 pulleys the WP and ALT are in the way
    • AWDBOB
      hooptie connoisseur
      • Aug 2013
      • 4503
      #122
      Originally posted by Anthony B
      -16an fittings from the pump to the block, according to the product info it 150L/min
      Going to see how it holds up to track usage, I’ve seen them on cars with more motor, more power, & driven harder than I will manage & they seem to hold up really well. But it’s the first ewp setup I’ve seen on an e30 so it will be interesting to see how it goes cooling the big iron block
      I used -12an by mistake before on tstat housing and rad outlets. Had a bunch of issues, then switch to -16an and it was happy. Great work in here.
      • jeenyus
        • Aug 2011
        • 2064
        #123
        That would make sense. I was in the mindset of a fuel pump and was thinking, that seemed really really high.
        I think this is such a cool idea. Especially in it's location, you won't have to completely dismantle your car to address any issues with the water pump.
        • Anthony B
          • Nov 2012
          • 308
          #124
          will hopefully be similar when I have the ati setup on mine, I’m now looking at electric power steering for this using a Holden astra pump setup
          • Anthony B
            • Nov 2012
            • 308
            #125
            hopefully all the effort in will make life easier down the track, I have 1 wire to fit & then I’ll be doing a run with the pump to burp the system & ensure it’s all working together
            • Anthony B
              • Nov 2012
              • 308
              #126
              Made some more progress on the weekend making the car look fast while it doesn’t run, splitter is made out of 3mm aluminium composite & I also ran the waterpump to bleed the system & had to repair a leak(read I didn’t have the hose clamp seated properly)
              Untitled by Ant Bolic, on Flickr
              • jeenyus
                • Aug 2011
                • 2064
                #127
                what did you use on the edge? Looks long enough for the rear bumper to get the same treatment, possible? I have similar stuff on my front bumper (similar to the M3 evo). I would be nice to match the rear.
                • Anthony B
                  • Nov 2012
                  • 308
                  #128
                  Used rubber pinchweld, it’s did well at cleaning up my haphazard cutting. On the rear I need to remove the tow hitch/modify it to be a jack point that’s on the car & mock up my hartge rear valance to fit with it. I’d really like to suss out doing a flat bottom setup on the car with a similar material, it seems like overkill but fyrc
                  • varg
                    Florida Turbo Man
                    • May 2014
                    • 3429
                    #129
                    That's a sweet looking engine. Looking forward to hearing it sing and seeing what kind of power it makes.
                    IG @turbovarg
                    '91 318is, M20 turbo
                    • jeenyus
                      • Aug 2011
                      • 2064
                      #130
                      This is super helpful. I would have never known the name of this stuff otherwise. I got some for my front bumper a while back (an actual BMW part) and it wouldn't have been long enough for the rear bumper doing the same thing. That being said, i was able to find an exactly same version on ebay and buy it by the length. Thanks again!
                      • Anthony B
                        • Nov 2012
                        • 308
                        #131
                        So the exhaust & ecu need to wait until after the wedding before I end up divorced before I get married, but I towed the car out to a car show at world time attack challenge which is the biggest Time attack event we have in Aus & one of the best in the world. The car show I was a little out of place with the stancie boi’s. But one of my best mates broughhis sedan along pwhich previously had an ls1 swap & is now running a peripheral port 13b and is a piece of perfection.
                        The livery is is new addition & is going to get more added to it over this coming season of racing, & the interior is tidied up(just needs its cage & harneses)
                        • Anthony B
                          • Nov 2012
                          • 308
                          #132
                          Thought I’d share a couple more, this is my favourite reaction photo captured by Matt Everingham
                          • AWDBOB
                            hooptie connoisseur
                            • Aug 2013
                            • 4503
                            #133
                            The car looks fantastic out in the sun. I got excited and thought I missed a post about it running and driving!
                            • rzerob
                              • Jun 2013
                              • 2315
                              #134
                              You need to invest in a hood shock or a collapsible hood prop. That broom handle is ruining these pictures in my opinion.
                              • Anthony B
                                • Nov 2012
                                • 308
                                #135
                                alas but it’s ever so close
                                yeah it’s not a great looking pool queue, the hood shock works perfectly unfortunately there was a 60km/h headwind that slammed the hood shut. I have the queue as my boot lid prop
