Another m30e30 & a new project
  • digger
    • Nov 2005
    • 6196
    #151
    Originally posted by Anthony B
    Very much looking at a bigger lift cam, Rama & I both discussed it being a limiting factor currently. To go to a higher lift I need to swap out to a steel rockers to get the benefit of the longer lash pad.
    This is the cam chart to the current one http://www.catcams.com/products/cams...nguage=english
    I’ve got my eye on the PPF offering http://server.pure-pf.com/webshop2/e...1-m30-z55.html
    along with these https://kmcams.com/products/bmw-m30-...el-rocker-arms
    the ENEM cam will be miles better than what you have......
    • lukeADE335i
      • Apr 2013
      • 1389
      #152
      Congratulations on getting the car back up and running Ant! Must be good to be driving it again. Hope the track day goes well over the weekend.
      191 wheel horsepower is about 25hp above what my stock M30B35 made in the e30 with a 2.5 inch single exhaust (here's my dyno plot from a dyno day few years back)... they don't call the dyno-dynamics dynos heart breakers for nothing! A stock M20B25 engined e30 on the same day made 101kW vs my 124kW. No doubt there'll be more power to be found as you develop your package a bit more.
      Here was my plot:
      My e30: OEM+ with M30B35
      • Anthony B
        • Nov 2012
        • 308
        #153
        The shakedown on the weekend uncovered the factory in tank pump is no longer up to the task I kept getting fuel pressure drops & starvation at full WOT. On the dyno it wasn’t evident as an issue but I think fuel slosh on track was the harder test. I have a 100 micron filter on the feed side & the pump wouldn’t pump through it so pulled it out just ran the intank filter on the pump but still wasn’t enough.
        Ordered an aeromotive stealth 340, also setting up a 2.5lt surge tank so the fuel feed side is over killed.
        • lukeADE335i
          • Apr 2013
          • 1389
          #154
          Should see the numbers jump with the new pump! There was an e28 with ITBs getting around Melbourne with 154 rwkW.
          How'd you go with the mods to the headers you bought? Was it just the number 1 runner that needed adjustment to fit or more than that?
          • digger
            • Nov 2005
            • 6196
            #155
            what injectors are you running?
            • Anthony B
              • Nov 2012
              • 308
              #156
              310cc Bosch units, they are reading 6% duty cycle at idle & 60-70% at full wot
              we pulled the feed hose after the filter & barely getting fuel, pulled the filter element out & it was better but still not the rate it should have been. On full WOT the fuel pressure gauge on the reg was dropping 10’ish psi.
              Aeromotive pump is ordered along with a longer body AEM high flow filter, going to change the plugs out at the same time as just preventative maintenance.
              • digger
                • Nov 2005
                • 6196
                #157
                sounds like the pump (OE??) is toast rather than not upto the job. New OE pumps are spendy though
                • Anthony B
                  • Nov 2012
                  • 308
                  #158
                  Was an OE pump but has been replaced in the past, the new one is overkill the whole fuelling side will be overbuilt now so I shouldn’t hit issues again.
                  • Anthony B
                    • Nov 2012
                    • 308
                    #159
                    Here's a few pics from the weekend
                    Untitled by Ant Bolic, on Flickr
                    I got to hang out with this e9 CS
                    the offending pump
                    & shooting the sh#t with my old man
                    & a small sound bite before i lost fuel pressure
                    • AWDBOB
                      hooptie connoisseur
                      • Aug 2013
                      • 4503
                      #160
                      Did you ever end up getting back to the dyno?
                      • Anthony B
                        • Nov 2012
                        • 308
                        #161
                        negative, however I’ve had 4 track events & it’s been brilliant. I picked up another project which is stealing time away from the e30 which is poor form on my part.
                        will be aiming within the next 2mths to get back to the dyno, install my half cage, & plumb in a 4kg extinguisher
                        I’ve got a 72 BMW 2500/Bavaria project on the go now that’s getting an e28 rear subframe swap & a Ford 347 stroker with a C4. After turning the e30 into a track car I convinced my wife I need to build a weekend cruiser..... that should have 350-400hp
                        • AWDBOB
                          hooptie connoisseur
                          • Aug 2013
                          • 4503
                          #162
                          I am VERY into that.... had Foxbodys in High School, so that hits close to home haha.
                          Excited to see progress, and glad you've gotten to use the car!
