Project: Spielereien. AKA "The dumpster fire"
  • delamaize
    • Nov 2013
    • 1460
    #196
    Parts showed up today, therefore, its go time.
    Click image for larger version  Name:	20260602_140339.jpg Views:	0 Size:	123.7 KB ID:	10161954
    decided to go to Pick N Pull and see what injectors the E39 that I pulled the crossover from had in it. It had 8 of the new style bosch 0280156347 injectors, that looked new. Needless to say, for $100 for the set, I jumped on them.
    Click image for larger version  Name:	20260602_144941.jpg Views:	0 Size:	135.2 KB ID:	10161955
    Click image for larger version  Name:	20260602_144948.jpg Views:	0 Size:	78.5 KB ID:	10161956
    Got everything Slammed back together, and gave it a crank. Took a second to reprime the fuel system, but we got life again, and no coolant leaks that I can see!
    Im so happy, and ready to Rip it again! Id take it now, but I have a banquet for my step daughters track team to get to.
    Dumpster Fire Pilot
    • delamaize
      • Nov 2013
      • 1460
      #197
      Dumpster fire update!
      I've had it back on the road for about 2 weeks now. And it is awesome still. Has not lost a drop of coolant since fix. The new fuel injectors are great, I had a noticeable power gain, in a little bit better gas mileage. The last tank of gas calculated out to 22 miles a gallon. I'm planning a few short road trips, be the first time I have pushed this car more than 2 hours away from my house. I did have the engine oil level light come on the other day when I was out driving, I worried about that a little bit, but I also put in a actual oil pressure gauge and I was still getting good oil pressure so I knew I wasn't low on oil. But to play it safe I pulled over and checked anyways. Just as I thought oil level is good, but the sensor has taken a shit. I'm on my way to the junkyard today to see if the 540 that I scavenged the fuel injectors, and the coolant crossover is still there. If it is I'm snagging that sensor. Those damn things are expensive brand new.
      on the list of dumb things that are just quality of life projects, I managed to find a 1988 Mercedes-Benz 300E that had a good power antenna at pick and pull near me. A little bit of Google foo told me that the antennas are basically the same as the E30. With the thing only costing 9 bucks I decided to take the Gamble. So they are not exactly the same antenna. The mounting is different. And there is no easy way to take the mounting off of the E30 and put it on the MB one. They are similar part numbers, and they are identical size and shape. Of course the electrical plug is different, and they are wired slightly different. What I ended up doing was taking all of the guts out of the MB unit, and putting them in my E30 cases. Luckily everything is modular enough that I did not have to do any soldering to swap the Electoral over, it was merely unplugging the pigtail between the board and the plug, and plugging in the BMW one. So now I have a working power antenna again, I know it's a gee whiz bullshit thing, but to me I like it. I have a modern stereo, a Sony DSX-A415BT, and I was hoping that when you had the stereo on anything but the radio it would put the antenna down. It does not unfortunately, so that being said, I shook the parts box and found a basic stock BMW on/off button that fits into the dash above the stereo, the same area as the hazards. I wired that button up to be a interrupt for the antenna, so if I'm running Bluetooth I can turn that button off and the antenna goes down. I know a trivial little bullshit thing but I like it.
      The next big project is putting in a higher volume/high pressure Fuel pump, and getting rid of E30 dual pump setup. What I got is basically a Warbo 300 equivalent. It should be more rhan enough flow and pressure. I have the new pump, and the stuff to do it, except the new High pressure line, that goes from the hanger to the fuel filter. I just need time. In the near future I do need to replace the gas tank though, it has had a big dent in and since I got the car, and it's in a place where I can't push it out from the fuel pump/Gauge hole. The most gas I've ever been able to put in this car at one time is 10 gallons, which means that dent is taking 2 gallons away from me. I might go to the late model tank, I got to do some more research to figure out what I have to do to make that happen. 16 gallons would be nice
      I still absolutely love this car, and these days I'm driving it More than my normal daily my 2010 F150. Definitely get better gas mileage. Stay tuned for more
      Dumpster Fire Pilot
      • delamaize
        • Nov 2013
        • 1460
        #198
        Been Dailying the Dumpster Fire sincen I fixed the coolant leak. It gets better milage that my F150, which I normally daily. I'm sure my neighborhood isn't thrilled with me starting it at 6:30 in the morning....
        Dumpster Fire Pilot
        • 2mAn
          SeƱior Mod
          • 20883
          #199
          At 22mpg I think you're getting mpg than I am in my M20!
          Simon
          Current Cars:
          -1966 Lotus Elan
          -1986 German Car
          -2006 Volkswagen Jetta TDI
          Make R3V Great Again -2020
          • delamaize
            • Nov 2013
            • 1460
            #200
            Well, Today is the day I decided to do my short-ish road trip with the Dumpster Fire, and the thing was absoulty flawless the entire time. 500 miles round trip all together. It was in the 90s in eastern Washington, and the Temp stayed rock solid the entire time. The thing did so awesome Im so happy with this thing overall. Oh, Yeah, Milage? I had to fill the tank 2 times altogether, started with half a tank, and refilled it at the beginning the trip, filled in Pasco, Wa, then again in Centralia, Wa. Home is about 30 Min from Centralia. Aaaaanyways. 23 MPG. Yes, you heard that right, 23 MPG, with a M60 swap. This car....
            Dumpster Fire Pilot
            • 2mAn
              SeƱior Mod
              • 20883
              #201
              E30s are so good!... glad it went flawless!
              Simon
              Current Cars:
              -1966 Lotus Elan
              -1986 German Car
              • delamaize
                • Nov 2013
                • 1460
                #202
                Okay for those of you that know more about BMW sensors and wiring, I've got a question. Recently the oil level sensor in my M60 took a shit. I was having a hard time finding a sensor that was not hundreds of dollars. I had read somewhere that the m62 oil level sensor was a acceptable replacement. So I went back to the 540i that I scavenged parts from earlier at my local Pick-n-Pull, and snagged the sensor from that motor. While I was at it I also snagged the wiring all the way up to the junction boxes on top of the motor. I grabbed the wiring for two reasons. One being that the m62 sensor uses a different plug than the M60 sensor, the other reason is, when I first did the swap that was one of the connections that have been cut in several places by somebody else, and just spliced the wires back together, to make it work. And it worked fine for years. I did Keep the old sensor, and the old hacked up wiring and plug. That way if I needed to go back to a original style sensor I could.
                I installed the new sensor when I did the oil change recently on it, and ran the new wires and plug. Unfortunately I got some bad information because that did not fix the issue. I still have my engine oil level light on. So I guess I have two questions overall.
                The motor came out of a '94 540i originally, does anybody know where I can get an oil level sensor that's not going to cost me $200+, or does anyone know what the 404 dmu is looking for in the way of signal to shut that light off. If it's something simple like installing a resistor or grounding a wire I think I will do that and just not worry about having an oil level sensor. I mean I manually check the oil on this thing every time I drive it, and currently I do not have any oil leaks at all from the motor, so the oil level sensor is kind of moot.
                Click image for larger version  Name:	20260802_095445.jpg Views:	0 Size:	93.3 KB ID:	10164815
                Click image for larger version  Name:	20260802_095455.jpg Views:	0 Size:	138.0 KB ID:	10164816
                Dumpster Fire Pilot
                • Northern
                  I like cupcakes & sh!tboxes
                  • 5251
                  #203
                  I think the oil level sensor stuff is through the Check panel module in the left side of the trunk, and is basically entirely e30 chassis side besides the sensor/wiring - no interface with the DME at all.
                  I think you can deal with it at the C101 connector.
                  I have a few notes on this but you should double check against the ETM because of the colour conflicts below...
                  "Oil static switch wire is Blue/Violet for Early E30, Green/Yellow for Late E30. Verify with ETM and connect to Ground."
                  "Connect Static to Ground per (dead e30tech link)"
                  Early Model C101:
                  Pin 2: Blu/Yel - Oil Level Sensor (I assume Static)
                  Pin 10: Violet/Green - Oil Level sensor (I assume Dynamic)
                  Late Model C101 (verified on my old '88 Eta):
                  Pin 2: GRN/WHT(Engine Harness) or BLU/BLK(Body Harness) - Oil Level Static (Full)
                  Pin 10: BLU(Engine Harness) - VIOLET/GRN(Chassis side) Oil Level Dynamic (Low)
                  I'd doublecheck vs the ETM and if it doesn't seem glaringly wrong, ground pin 2 on the engine harness side and see if that resolves it.
                  Originally posted by priapism
                  Originally posted by shameson
                  • delamaize
                    • Nov 2013
                    • 1460
                    #204
                    Early Model C101:
                    Thank you bro, I'll mess with it today, and post the results later.
                    Dumpster Fire Pilot
                    • delamaize
                      • Nov 2013
                      • 1460
                      #205
                      Well, it took me longer than I anticipated to get the time to do it, but I got it done.
                      Grounded the wire in the wiring box on the engine its self. Found that Blue/ white, White, and brown go from that box to the sensor. Grounded white to brown, light shut off.
                      So, this will do the job, until I can find a 94mm sensor that isnt $250+. Im sorry, I dont want to spend that much on a sensor that basically just turns off a light. Add to that I check my oil frequently, its seems like a waste of money.
                      Dumpster Fire Pilot
