Mike's Alpine White 1991 318is
I got out for some quick photos at sunrise. Also, I ordered something from Europe last week and should have some photos of that soon. ;D
just was going through your thread to get a few details for my "is" restoration.
In any event, all you had to do in order to check for LSD is to raise the rear of you car as in your pic above. Spin one rear wheel and watch in which direction the other side is spinning:
the same direction - LSD
the opposite direction - open diff.
This applies to any other cars and 100% sure way to tell regardless of tags and stampsComment
Yep! As I mentioned in a later post the wheels spinning in the same or opposite directions only applies if the car is in neutral. If the driveshaft is fixed due to the car being in gear, even an LSD will spin the wheels in opposite directions, making it appear to be an open diff. When I had tested the diff 3 years ago I had the car in gear, coupled with not seeing the diff tag and the car not originally being equipped with LSD, I incorrectly assumed it was an open diff. Still drives me crazy I overlooked this!just was going through your thread to get a few details for my "is" restoration.
haha. I didn't even think that anyone would ever attempt to fight with the transmission and spin the tire with the car in gear. I guess there is always someone who will.... :DYep! As I mentioned in a later post the wheels spinning in the same or opposite directions only applies if the car is in neutral. If the driveshaft is fixed due to the car being in gear, even an LSD will spin the wheels in opposite directions, making it appear to be an open diff. When I had tested the diff 3 years ago I had the car in gear, coupled with not seeing the diff tag and the car not originally being equipped with LSD, I incorrectly assumed it was an open diff. Still drives me crazy I overlooked this!Comment
Why not just drop the clutch and see if you get two skid marks [emoji2375]
Drive Tastefully!FEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
Didn't do it on purpose! I'll be the first to admit it was a complete botch and embarrassment.
This!Comment
Dam good looking car bud! I was considering painting mine white
Sent from my iPhone using TapatalkComment
I’m talking about a MAN’s burnout...[emoji2363]
It’s very easy to tell if you have traction on both axles
BMWCCA #398608
IG @yagayo38
It keeps quite well.just was going through your thread to get a few details for my "is" restoration.
DMC Prep Part 3: Interior and final wash
I have a busy week ahead, so I cleaned the interior today and gave the exterior a final wash before DMC next Sunday. Fingers crossed the weather will be good!
Jesus that car is friggin' clean, looks brand new.'86 325e Zinnoberrot /// '02 325ci Schwarz II /// '18 M4 Azurite Black Metallic ///
Albie325 Build Thread | Albie325 COTM Jan 2021Comment
