March 2017 Car of the Month: mitchlikesbikes
  • 2mAn
    Señior Mod
    • 21014
    *** Editors Note: Yes, I know. This car has a beat paintjob. Nobody will argue that. So, why is this car of the month? Look at what Mitch has done, thats why. He took a beat, stock E30 and made it into a driver, and made it his and it will continue to evolve. Maybe someday it will have a nice paintjob to go with all the other cool stuff. This car deserves to be Car of the Month, and if you disagree, send me a message with a better choice. Congrats Mitch! - Simon
    Color:
    -Zinnoberrot
    Interior color:
    -Zinnoberrot
    Engine modifications:
    -200,XXX mile m20
    -Conforti 91 octane chip
    -Hot air intake w/ K&N cone filter
    -AC and PS delete
    -Cruise control delete
    -Odyssey 680 lightweight battery in a Pacific Customs box
    -Bypassed/shaved TB heater
    -Walbro 255 fuel pump
    Exhaust:
    -OEM manifolds merged into a single 2.5" with high flow cat and twin tip muffler custom made by Walter at Simple Performance in Salt Lake City
    Transmission:
    -Leaky Getrag 5 speed
    -Z4 2.5 lever
    -Alacrity Machine delrin shift knob
    -Delrin carrier bushings
    -UUC DSSR
    -Driveshaft harmonic balancer delete
    Differential:
    -3.73LSD with redline 75-140 gear lube
    -Condor UHMW bushing
    Suspension:
    -KYB shocks on all 4 corners
    -Vogtland Springs
    -Condor bushings in rear subframe and trailing arms
    -Treehouse FCABs
    -E36 steering rack
    -Custom shortened steering shaft
    -Garagistic aluminum PS delete block
    -APEX wheel stud conversion
    Brakes
    -RX7/Corrado front brakes using adapter kit produced by Cameron out of Cedar City, Utah
    -Hawk HPS pads and blank rotors on all 4 corners
    -MassiveBrakes booster delete block
    -1970s era Audi Fox/VW dasher master cylinder
    -Wilwood adjustable proportioning valve
    -ABS delete
    -Custom brake ducts using 3D printed inlet adapters, 3" ducting, and homemade backing plates
    Wheels:
    -Avid AV17 16x8 +20
    -Bridgestone Potenza RE11 in 225/50/16
    Exterior modifications:
    -iS trunk spoiler
    -Speed holes in front bumper
    -Condor motorsport door handles
    -Sunroof delete with riveted steel panel
    -i model front lip
    -BMW fog light delete plates
    -Shaved side markers (essentially DIY euro bumper trim)
    Interior modifications:
    -Gutted/stripped most of the interior including sound deadening and all side panels, headliner, etc
    -Full interior sprayed with epoxy primer and Zinnoberrot single stage paint
    -Front floorboards coated with Herculiner
    -Roll Cage Components .120 DOM 4 point weld in roll bar fitted by my dad and I.
    -Cobra Suzuka fixed back seat
    -Mtech1 wheel
    -Custom ABS door panels with GT3 RS inspired door pulls
    -Flocked dash/glovebox
    -Center console delete
    -Window switches relocated to hvac panel
    -Chili's potholder Ebrake sock
    -Shaved most HVAC controls/radio and filled with ABS block off plates
    -Pyle 2 channel amp with AUX in glovebox and 2 front mounted kicker speakers
    -VDO oil pressure, oil temp, and battery voltage gauges
    -Power mirrors, door locks, dome lights, etc deleted
    -Excess wiring trimmed and harness wrapped with braided loom
    -Heater box shaved and sealed to only use defrost vents. All other vents/actuators deleted
    Story behind the car
    I purchased the car in 2013 when I was 19 for the bargain price of $700. It started off mostly stock with a beat tan interior, toasted suspension components, and a few bizarre/poorly executed mods from the previous owner (like 6x9 speakers mounted to the rear deck using wood screws). Since then I've used things I wanted to do to the car as ways to teach myself different skills/techniques for building cars (fitting/flaring brake lines, trimming wiring harnesses, fabricating random one off pieces out of whatever material worked, fitting a roll bar, etc). Up to this point the car has been almost entirely garage built by me with occasional help from friends. The only major work outsourced so far has been powdercoating, exhaust fabrication, and alignments. When building the car my main goal was to emulate what joey at emotion engineering has done with his "project nasty" Porsche 911. I'm hoping that next winter I can button more things up on the car (like adding coilovers, and resealing the engine/trans to eliminate pesky leaks) and enter with the car in the Nevada silver state classic rally in the fall of 2018
    Build Thread is here
    2_zps1dlsb4li by 2mAn
    3_zpslx99zeam by 2mAn
    9_zpsjjrxn7ey by 2mAn
    10_zps6ydzybu3 by 2mAn
    4_zpsiuff0go9 by 2mAn
    5_zpswjod8pkk by 2mAn
    6_zpscyluycwi by 2mAn
    1_zps2eevnmch by 2mAn
    8_zps4flkkmpe by 2mAn
    7_zpszpsdycxy by 2mAn
    Simon
    Current Cars:
    -1966 Blue Boat
    -1969 Red VW
    -1986 White BMW
    -2006 Green Thing
    Make R3V Great Again -2020
  • JeLani
    • Aug 2015
    • 1552
    Chilis e brake boot ftw!
    1986 LTW M52 (First project 2015- )
    1998 e36 328ic/5 -
    Roundie alpina pig cheek’d (1969)
    1967 2002 parts car
    1994 318iS junked.
    • getouth
      • Jan 2010
      • 3343
      That thing looks like a lot of fun!
      FEEDBACK:
      http://www.r3vlimited.com/board/showthread.php?t=316212
      BMWCCA #398608
      IG @yagayo38
      "The Best E30's were built with two camshafts four cylinders and sixteen valves!".
      • zwill23
        • Jul 2015
        • 615
        Not that I don't love pristine E30 builds with gobs of power, but it's awesome to see some rough and tough E30's getting some love. Thing looks like a hell of a ride, and hat tip to using her to learn the skills of the trade. Very similar mentality over this way.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5603
          Cool seeing a car like this get car of the month.
          • 2mAn
            Señior Mod
            • 21014
            I was worried I'd get sh!t for picking Mitch's car but the whole point of Car of the Month ( at least while I'm doing it) is a car that the owner has built for themselves. Take inspiration from wherever you want but make it yours. Mitch has definitely done that
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            • Mushi
              • Apr 2014
              • 1033
              Noice.
              • mitchlikesbikes
                • Dec 2013
                • 858
                Thanks for the kind words guys. I was expecting a shitstorm myself haha
                IG: @mitchlikesbikes
                • Zacm829
                  • Jan 2008
                  • 1919
                  Car looks fun and unique, have you done any driving events with it?
                  1987 325i-M60b44 swap
                  • mitchlikesbikes
                    • Dec 2013
                    • 858
                    Not yet, still a poser. The car hasn't been to a point where I was confident throwing it around a track until now. Mostly because of brakes and suspension gremlins. It also leaks a fair amount from both the engine and trans and I don't wanna be that guy marking his territory all over the track
                    • stonea
                      • 2892
                      looks like a true old school r3v build, congrats on COTM!
                      My Garage
                      Feedback
                      Instagram: Stone.Hopkins
                      • markseven
                        • Sep 2006
                        • 5327
                        Hot air intake. So avant garde!
                        Like the car and the write up.
                        I Timothy 2:1-2
                        • 2002maniac
                          • 4260
                          Congrats Mitch! The car seems to be very well sorted!
                          • mitchlikesbikes
                            • Dec 2013
                            • 858
                            Thanks folks!
                            • paynemw
                              • Dec 2015
                              • 439
                              Get on the track!!! nice purpose built e30.
