This build escalated quickly...
  • masterofnone
    • Oct 2018
    • 99
    Hey guys,
    Thanks for the add! Long time creeper, its about time I join this community. Over the years I have dug up tons of useful information from you guys, thank you. Hopefully this can help others out there as well. I know Im still going to need help, already have some questions in mind aha.
    Heres what Im working on. In March 2017 my E30 ended up on the back of a flatbed. I pulled off the freeway after a couple hundred mile trip and the car was misfiring bad. Next morning I started the car and it sounded like it was knocking.
    The Build by Evan Nessim, on Flickr
    Since the engine seemed tired I decided to pull the motor and do a full stock rebuild to get back on the road.
    All torn down. Something must have been jumping around in a couple cylinders for sure. Didnt have a clue just how worn the engine would be. So I figured may as well build a 3.1 stroker! I started making a build list and in the mean time cleaned up around the car.
    Little elbow grease here and there.
    Pulled out some aftermarket wiring, door locks never really worked well.
    Well, by the time I calculated parts and machining for the 3.1L M20 I decided there might be a more "cost effective" solution. So I bought this with 82k miles on the tach.
    Pulled the engine, took what I needed from the chassis and sold it as a roller.
    My plan was to rebuild the S54 with ARP hardware and coated bearings thinking it would all just fall back into place, the engine decided otherwise... And I thought it looked pretty clean as it was coming apart. Starting with the Vanos tab issue, the rods were out of round, the mains needed to be lined, the crank was bent, the new main bearings had too much crush, and valve tolerances were all over the place. In short, waiting to sort out all these machining/engine issues has been the longest part of this build. Ive been stagnant for months waiting to plumb and wire everything.
    Getting tired of copy and pasting for now, Ill update with the chassis side of things and the engine reassembly later.
  • Cptcarisma
    • Jan 2011
    • 466
    Now THATS a 1st post!
    Welcome Mr Master!
    CAPP... :-)
    • shawmcbigdis
      • Apr 2018
      • 164
      Welcome Mr Master!
      CAPP... :-)
      Agreed. Very first post is diving into an S54 swap, that's awesome. Can't wait to see how this pans out.
      Good luck!
      2002 530i - Daily
      2013 Ford Flex Ecoboost - wifes/family hauler
      1986 325es - fun car (or money pit depending on who you ask)
      My build thread - https://www.r3vlimited.com/board/sho...d.php?t=422370
      • rzerob
        • Jun 2013
        • 2315
        Subscribed.
        • KIRIEIW
          • Dec 2012
          • 3385
          Oh damn this one's gonna be good.
          1992 e34 Touring- S50 Swap
          1992 325i-S50 Swap (SOLD)
          1991
          • Julien
            • 7472
            Looking forward to how this turns out!
            Build Threads:
            • george graves
              • 20003
              "Motor had some knock....so I bought a m3 vert to then sent it on it's way."
              Originally posted by Matt-B
              • jeenyus
                • Aug 2011
                • 2064
                Good first post. Welcome.
                • wworm
                  • Dec 2016
                  • 1719
                  holy crap. I'm excited lol
                  1984 Delphin 318i 2 door
                  • AWDBOB
                    hooptie connoisseur
                    • Aug 2013
                    • 4513
                    Sorry to hear of the S54 issues. I'm excited to see this build come to life, though.
                    • masterofnone
                      • Oct 2018
                      • 99
                      Decided to chop up my front subframe and ship it out to Tyler at the ArcAsylum along with my oil pan and headers despite reading about how difficult it is to contact him. I got the subframe and oil pan back and it is damn beautiful. However, Tyler still has my headers and it has been over six months since he said the completed exhaust system would originally ship out. I see that he has taken great time to create a much improved ArcAsylum website and explain that he is swamped so hopefully this means Ill be seeing a completed exhaust with my headers by the time I have the engine running. Tyler is indeed hard to contact, but his work is unquestionably well done.
                      Friend stopped by in a slick black Porsche with gold BBSs.
                      Subframe installed along with Z3 steering rack, AKG steering column kit and AKG 24V swap engine mounts. Stock sway bar for now, IE mounts with AKG adjustable endlinks. Like a glove!
                      New E30 control arms and E36 steering rack endlinks. Running powerflex FCABs unless I need to switch to something else due to exhaust clearance.
                      Z3M four core radiator and linear A/C condenser. I am determined to have proper A/C for the first time since Ive owned the car haha
                      Thinking about mounting the overflow here somehow, waiting to see where the plumbing will fall.
                      Rear end going back in using AKG 95A subframe mounts, AKG 85A diff mounts and powerflex trailing arm and sway bar bushings.
                      Had to modify my dust shields to clear the BBK while retaining the ebrake system.
                      Coat of paint for the dust shields and the stock booster that probably won't fit.
                      Test mount of rear calipers and pictures of Lee’s Massive 300x32mm kit with Wilwood SL4 calipers. Pistons are 1.625” front and 1.25” rear according to Lee’s recommendation.
                      Ebrakes for floating rotors, hell yes.
                      Meanwhile, this is what happened to the S54 donor vehicle!
                      As soon as I get back from my trip I’m getting back to the the grind! I’ve been waiting for this moment.
                      • 2mAn
                        Señior Mod
                        • 21062
                        I cant tell how many times you posted the same thing... I already deleted 3 duplicates...
                        2-things:
                        1) The coolant overflow: you can use a stock E30 M3 unit as thats where it was placed in that car, no mods necessary.
                        2) Take the alpineweiss sticker off the engine bay and get you a zinno one, it looks fairly close to a zinno paint
                        Simon
                        Current Cars:
                        -1966 Blue Boat
                        -1969 Red VW
                        -1986 White BMW
                        -2006 Green Thing
                        Make R3V Great Again -2020
                        • masterofnone
                          • Oct 2018
                          • 99
                          2-things:
                          Shoot sorry, it wasn’t showing up on my side. Once again it’s not showing up but maybe that’s because it was deleted? Is it possible the reply posted and i can’t see it?
                          Thanks, and the alpine sticker was removed as well as the white underneath painted. The car is supposed to be imola but is in fact a little brighter in direct light.
                          • masterofnone
                            • Oct 2018
                            • 99
                            Alright, lets try this again. Maybe I was trying to post a novel so it wasn't uploading right? Ill break this down.
                            Other than that Im here to show you what Ive done over the months while waiting for parts or machining.
                            Bunch of chassis reinforcement and suspension adjustment bits from AKG.
                            The trash can turned out to be a better welding table than expected haha
                            Trailing arm adjusters.
                            Rear sway reinforcement.
                            • masterofnone
                              • Oct 2018
                              • 99
                              The S54 deserves a pretty backdrop, so I started getting crafty. The car was originally alpine white so I cleaned and prepped the bay as best I could getting ready for paint. There’s an auto paint store close by that sells professional quality, accurate single stage paint in a can. Works very well for non metallic colors.
                              Used a fan and a box with filters and cut out exhaust holes to try to keep the paint particles down, worked pretty well! Laid down multiple coats with plenty of time to dry in between.
                              Im very happy with the result, much better than spotted bits of white and cracked heat insulation.
