Status of my e30....
  • diegom6
    • 4447
    Couple of thing sneed to be done after she run again in the streets. BBK are almost done.
    Euro M3'87 NogaroSilver/Euro E34 M5 '93/Porsche 993 TT 97' Euro/Porsche 993 Carrera 95' Euro/Skyline R33 GT-R
  • Widm3r
    • Jan 2006
    • 1129
    I havnt seen many photo's of your car, it is very clean, did you stroke the motor to a 3.0 from the m20? Is it mauritius blue?
    • moatilliatta
      • 6158
      what radiator is that? is that a stainless steal or polished aluminum reservoir? more info pls. you gunna have a windshield reservoir
      @Zakspeed_US
      • diegom6
        • 4447
        It's Avus Blue from the E36 m3:)
        It's stroked to 3.0L in htat m20 with M50b30 crank and rods, custom forged pistons yielding 8.3:1CR.
        I will post pics of her once is odne, overall :D
        Thanks
        • MIZTERIO
          • 993
          dammmmmmmmmm mannnnn..
          IT IS BETTER TO DIE ON YOUR FEET THAN LIVE ON YOUR KNEES - emiliano zapata!
          • diegom6
            • 4447
            It's a e36 318i RAD, that other little polished thing is a OIL CATCH CAN.:)
            • Mastrcruse
              • Sep 2005
              • 5340
              What did you wrap the turbo's tubing with? (the white wrap) Was it a sleeve or was it like a roll of tape? Great lookin car and awesome job. Do you plan on getting it dynoed?
              • Digitalwave
                is a poseur
                • 6302
                Looks freaking great man. When are you going to be driving it again?
                RISING EDGE
                • diegom6
                  • 4447
                  The heat wrapp you mean? It's a header heat wrapp insulator roll that you get it from Summit racing, it's thermotec, also I bought a Turbo insulating Kit , Thermotec brand from there.
                  I'm goign to dyno it once I figured out the prper tunign with the stand alone system.
                  Thnaks TJ, my engine it's "breaked in" and will take her for a conservative spin arround the town if luck it's next to me for the next week.:D
                  • MIZTERIO
                    • 993
                    good question
                    • lordofmpower
                      • 153
                      How much boost are you planning on running those turbonetics wastegate’s are notorious for boost creep. I would go TIAL all the way. Nice job man it looks extremely well done. Glad to see you have everything wrapped up tight. Are you going to put spray on those heat wraps? Can’t wait to see the results of your hard work! Also what standalone are you going to run
                      • rede30
                        • 4697
                        is the e36 318ti radiator better than the e30 318 rad? Fat car man, good luck finishing it up, i hope for you it gets on the road fast.
                        • diegom6
                          • 4447
                          Are knockoff HKS 40mm WG's. I used one in the past with good results. As far for boosting, well, no more then 20-21 PSI for now, unless I change the rocker arms, valve springs and bigger cam, it won't pass of those values and turn up the boost til 30 PSI or so with good tuning. I'm using Mega Squirt, soon to have WASTED PARK.
                          I have welded water chanels and oringed head though.
                          The 318i E36 RAD works fantastic in my car, never reach the middle in my temp gauge.
                          Here a couple of pics I took over the process, you can see the oring head, welded water chanels, turbo polsihed, forged pistons, oil squirt injector for pistons added, etc etc.
                          -Diego
                          • Mless5
                            • Jul 2006
                            • 817
                            Holy mother of snails!
                            '96 328is
                            '97 m3
                            '04 zhp
                            • JJe30
                              • 2044
                              That's pretty sweet
