No More stinking AFM!!
  • golfdmb18
    • Dec 2005
    • 886
    Originally posted by DaveCN
    Ely,
    THe lunch ladies want their trays back . . .
    lollollollollollolllollolloooo :p
    • CleanAzzE30z
      • Jan 2004
      • 11794
      Im going Alha N as soon as my shit gets here from Germany so Im in the same boat!! Congrats!!
      Mariano
      • EtaSport
        • 2853
        This was my next project. Still is in a way. I'll be using an m50 maf, just not on an m20, 8)
        I'll bet your pretty happy with your motor. I picked up a 3.25 LSD for mine which helped a bit, but didnt give me the "OMG this is the best mod for an ETA" kinda feel like most people say. I have 2 cylinders leaking above spec past the rings, so my 2.7 projects are over for now.
        Old and improved:
        • rs4pro3
          • 5808
          Ya I love it, with the hot cam, it realy is only happy if you give it some gas of the line. But man it takes of quick, I currently have a 3.73 open in it, and break the BFG g-sports loose way to easily. I'm going to start looking for a limited slip, the 3.25 was just too low geared, I'm thinking maybe a 3.91 will be perfect :shock: :crazy:
          85 325e 2.7 ITB'd stroker
          • 96 Cosmos
            • Jan 2006
            • 366
            Originally posted by rwdrift
            Impossible. Average r3v budget is $30.
            LOL!
            • JOE BMW
              • May 2005
              • 346
              How does your setup compare to a unichip? So you did the tuning? or did you get it tuned by a shop? Have you dyno it yet?
              www.ZeppieriMotorsport.com
              • rs4pro3
                • 5808
                I'm not familuar with the unichip, I did the tuning my self, it wasn't hard at all. The apexi unit is so easy to use, and on the fly adjustments are no problem. I've been driving the car all around the last 3 days, everything from steep mtns to interstate. And it's been running just fine under every condition. Found something interesting today, I set the apexi to measure Air flow, throttle, and rpm's At 6400 rpm's and 100% throttle, Maf was only flowing 51% of it's capacity according to the Apexi, where as before with the AFM it was 100% @ even lower then 6400 rpm's. If the Apexi is reading the air flow correctly, that's almost twice and airflow improvement from swapping to the MAF.
                • TerribleONE
                  • Jul 2006
                  • 501
                  how much of a difference do those heat shields make? how much do they go for?
                  1991 318iS swapped w/ euro S50B32
                  -Michael
                  • rs4pro3
                    • 5808
                    if you want to run a cone filter get a heatshield, plain and simple. I purchased this one off a forum member for around $50 I believe.
                      • 37832
                      Looks great Ely, I like the air filter setup a lot.
                      Classic BMW Specialists
                      Grover Beach, CA
                      www.BimmerHeads.com
                      • gstuning
                        • 833
                        what did you do to the fuel pressure?
                        If your sending out 2.5v into the stock ecu for a air flow that used to be 4,9v the load input is wrong and the timing will be off, i.e advanced for alot less load (less air) and thus might be to advanced,
                        Gunni
                        @ Prodrive / Aston Martin Racing
                        • RobertK
                          Kicked cancer's ASS.
                          • Jun 2005
                          • 5864
                          More around $37.68 (Adjusted for inflation)
                          Nice work Ely. Next time we meet up you gotta let me actually drive the car.
                          • rs4pro3
                            • 5808
                            fuel pressure right now is in the ~40 psi range. The apexi could very well be reading the MAF's output wrong, as it just reads the output voltage, and compares it I believe a 5v scale, it could be comparing it to a 12 volt scale. I'll mess around with it some more sometime.
                            • Kruzen
                              • Mar 2004
                              • 5603
                              Thanks for ignoring me fags
                              Originally posted by Kruzen
                              forgive my ignorance but what exactly is the benefit of all of this, or the difference i guess..
                              Who doesn't love a little BBQ?
                              Griot's Garage at a Deep Discount
                              • rs4pro3
                                • 5808
                                Do a search! But it's been discussed already, less restriction in the intake, better throttle response, and more noise:D I don't feel like it's worthwhile on a stock engine, but mine is far from stock.
