1984 318i build
  • packratbimmer
    • Dec 2009
    • 1335
    Originally posted by HENNAROT318i
    I was wondering if this is something rare, as I have yet to see another one. I am trying to find some info on it before I start trying to clean it up and possibly ruin it.
    Interesting! I have only seen one in my life. Where? On the back of my 1984 Euro 318i back in the day.
    • packratbimmer
      • Dec 2009
      • 1335
      Came home tonight at a package of goodies, my injectors came. I decided to throw them in real quick. They seem to have fixed my super rich running problem, however now I have discovered it is way out of time. So I guess I will have to work on setting the timing.
      Fill it with 93 octane - run it a little bit - find a hill - advance the timing until it pings a little - back off timing a smidge until the ping goes away. BTW from what I can remember, there are two possible pistons back in 1984 (round dome and piano dome, but not a piano like a BMW 2002). I suspect the two different pistons offered specific compression ratios. One might require 93 octane and the other not.
      • HENNAROT318i
        • Jul 2021
        • 28
        Thanks for the tips packratbimmer. I will check those things out while I have the pan off. Hopefully everything is ok, because the car only has 91k on it. I did do a compression check and had 150 across all four cylinders.
        • HENNAROT318i
          • Jul 2021
          • 28
          I had an impulse buy that showed up, a 410lsd. Probably shouldn’t have bought it right now, but for $400 I couldn’t pass it up.
          • 2mAn
            Señior Mod
            • 21031
            Hopefully that cloth rear seat cover that you replaced with the matching leather wasnt ruined. Quite a few people would've given you some money for that
            Simon
            Current Cars:
            -1966 Blue Boat
            -1969 Red VW
            -1986 White BMW
            -2006 Green Thing
            Make R3V Great Again -2020
            • HENNAROT318i
              • Jul 2021
              • 28
              I still have it along with the front seats, planned on trying to sell them.
              • 2mAn
                Señior Mod
                • 21031
                Smart, with a tight budget you should definitely sell the cloth interior. Not a common thing in the US so its desirable. Maybe try and package it as a whole interior deal with the door panels. You can easily get some tan vinyl door panels and by selling the interior as a complete package you should be able to get a nice amount to someone who wants the cloth
                Id sell the rear wing too personally
                Keep it up
                Simon
                Current Cars:
                -1966 Blue Boat
                -1969 Red VW
                -1986 White BMW
                -2006 Green Thing
                • HENNAROT318i
                  • Jul 2021
                  • 28
                  Decided to tackle the diff swap today.
                  • HENNAROT318i
                    • Jul 2021
                    • 28
                    The swap was a failure, the 410 diff is 3/4inch longer than the one in my car. I tried for 3 hours to get it to fit before I gave up. I thought the driveshaft would telescope some like on the muscle cars I am use to working on. So without the driveshaft able to telescope the diff will never fit. 😔
                    • tyeler18
                      • Jul 2019
                      • 141
                      It does telescope at the center support bearing, yours probably pulled out some while removing the old diff. Either way a rubber mallet will smack it back into place. An e30 diff is an e30 diff, doesnt matter if it's medium or small case they both interchange the same.
                      • HENNAROT318i
                        • Jul 2021
                        • 28
                        Just tried to tap in the driveshaft and it won’t budge, guess I have to take more stuff apart to find out why.
                        • 2mAn
                          Señior Mod
                          • 21031
                          Move further upstream towards the middle of the car. You'll see that its a two piece driveshaft. Likely will need to take a few more parts off, and being an old car that probably has never been taken apart prepare the curse jar and have lots of penetrating fluid on hand. You'll get it, its just going to take longer than expected to knock it out.
                          Simon
                          Current Cars:
                          -1966 Blue Boat
                          -1969 Red VW
                          -1986 White BMW
                          -2006 Green Thing
                          • HENNAROT318i
                            • Jul 2021
                            • 28
                            Took 2 hours to get the driveshaft to telescope, and another hour for the diff. It is finally back together and ready to go.
                            • packratbimmer
                              • Dec 2009
                              • 1335
                              It good to have that joint free anyway so there is a little give in the drivetrain. Speaking of a little give: How are the rear subframe mounts while you are in there?
                              • HENNAROT318i
                                • Jul 2021
                                • 28
                                didn’t look bad, but I am debating on buying a kit like this one:
                                https://www.ecstuning.com/b-assemble...yABEgKzwvD_BwE
                                Considering it for for better handling and also to make sure it is safe for my wife to drive.
