450v
  • amcp
    • 489
    Someone's not playing around here. Thanks for sharing!
    • dvallis
      • Oct 2015
      • 1474
      In the process of replacing this ancient lump on the Pullmax. 1963 Swedish 440V, 3 phase, 2 speed motor.
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        Decided to use this motor
        NIDEC, 5 HP, 3 phase, 220V, 3525 RPM, NEMA, Fan Cooled, 12A FLC
        Plus a a 7.5HP ABB VFD from ABB (ACS355-03U-24A4-2+J400). Has an excellent user manual
        We'll re-use the original 400V FAST/SLOW/STOP buttons in the pic above (Yeah. They were directly contacting 400V!) as 12V inputs for the VFD
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1474
          Haven't given up, just slow going lately. Things are picking up again now the weather is finally cooling off.
          I finished making a control box for the Pullmax. It communicates with the VFD I/O.
          Schematic
          Here's the box with test wiring. Will ultimately be mounted on a pedestal. Upper left is speed, 1000 RPM per volt. Speed control pot to the right. Below that is speed selector switch: left=slow, center=variable via pot, right=fast. Along the bottom from left are stop, start and jog buttons.
          Slow part was sourcing quality switches and buttons. Amazon stuff is crap. I looked a lot on eBay for used Allen Bradley gear. Great feel and will last forever.
          Up next, changing the seals and oil on the Pullmax.
          2002 E39 M5
          • 808ETA
            • Nov 2018
            • 436
            Woah!! This is going to be an awesome thread!
            sigpic84 325e
            • iXguido
              • Nov 2009
              • 730
              Definitely going to be following this!
              • dvallis
                • Oct 2015
                • 1474
                Pullmax is alive!
                But how the #$%%% can I embed the video? Did admins change this?
                2002 E39 M5
                • AceAndrew777
                  • Feb 2022
                  • 93
                  Absolutely killer. Will be following this very closely.
                  • dvallis
                    • Oct 2015
                    • 1474
                    I owe you guys an update. We've been busy.
                    Wiring the VFD
                    Replacement knob for a Pullmax handle. Works great.
                    Extracting 240 lb Harbor Freight English wheel from my E39 M5 without help. Engine lift saved my back.
                    Some assembly required
                    Finished product. Needs some weight at the back. Rob wants to bolt it to the floor instead. I got the extra lower anvils from JEGS. They are EOL from Harbor Freight.
                    Rob scored a nice cubby shelf for organizing Pullmax tooling.
                    Pullmax and control box
                    NOW we can start making the car! Hmmmm. I've got some work ahead of me.
                    First test: Use the Pullmax to make a bowl.
                    Shear tool and guide to cut off a piece of aluminum
                    Circle guide to cut a round piece from that
                    Thumbnail die for shrinking. I'll use a polycarb die instead of steel one for the body. Leaves less dings.
                    Setting up Pullmax dies is an art. You jog the upper tool to lower dead center, then use the lower hand wheel to raise the lower die until contact. Then add consecutive 1/8 turns on the lower hand wheel until the "machine sound changes" while jogging. That means it's doing work. Back off 1/16 of a turn, tighten the lower collar then get to work. Periodically re-adjust while working the metal.
                    Doming die for stretching
                    (a few hours later)
                    And Voila! A bowl and couple of cheezy fenders. Now I'm dangerous.
                    We need to fab the tube frame before getting serious on body panels. Blue tape was awesome for frame planning on the buck.
                    The take-off showed about 250 feet required, including drop and overage.
                    After looking at a variety of tubing 0.50" x 0.030" DOM steel is the material of choice. Hard enough to bend, but not TOO hard. EMT was just for reference. Don't use seamed tube on a frame.
                    For safety sake, the crash cage will be built onto the C5 frame. Big, strong 1.5" DOM steel door bars, cockpit surround etc. The 0.5" DOM is just carrying an aluminum body.
                    That's about everything for now. I'm getting three quotes on 250' of 0.5" x0.030" DOM tubing and will pull the trigger on that this week.
                    EOM
                    2002 E39 M5
                    • 2mAn
                      Señior Mod
                      • 20954
                      Love this kind of stuff!... I have had a few attempts at building something wild like this. None succeeded but we press on and try again
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • dvallis
                        • Oct 2015
                        • 1474
                        Time for a pre-holiday update.
                        Acquired 250' of 0.5" OD 0.030 DOM for the frame
                        Building tube bender jigs
                        Building somewhere to store all our material
                        All that steel in the back corner goes on these shelves, plus aluminum square tube, the frame DOM, aluminum sheets, steel plate etc. Need to clean up and get organized before starting fab.
                        2002 E39 M5
                        • dvallis
                          • Oct 2015
                          • 1474
                          Cleaned up, organized, ready to go
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            Finally got a PC and big screen at the shop. Can reference my CAD for the build in real time. You can see the buck, body and frame overlayed.
                            Front frame bar interfers with the body. Needed to go.
                            Take out the bolts, break the glue, chop it in half and apply leverage.
                            Turned out great. We'll replace it with a 3"x3" square tube welded straight across.
                            2002 E39 M5
                            • bangn
                              • Sep 2011
                              • 760
                              wow this is a cool build! the sheet work forming is no joke! very cool
                              Boris - 89 E30 325i
                              84- E30 323i
                              • dvallis
                                • Oct 2015
                                • 1474
                                New frame bar done. Might weld on a top L bracket to each side but otherwise that's all.
                                Body frame is next. We're starting with the cockpit surround.
                                2002 E39 M5
