450v
  • Dj Buttchug
    • Jun 2010
    • 7677
    #31
    insane build! sub'd
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • dvallis
      • Oct 2015
      • 1474
      #32
      Notching the buck
      Finally we start the tube frame bending. This will be the rear bar of the cockpit surround. The overall plan is to have a 1.20" DOM tube frame "backbone" with 0.50" making the rest of the frame.
      Remember, this is not structural. The C5 ladder frame provides ALL the chassis stiffness. Our superlegerra tube frame just supports the aluminum body skin. Here's an example
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1474
        #33
        Time for the Weekend Update ....
        Using a DOM scrap to notch the buck
        Harbor freight tube bender. As usual, some tuning required to make it work right.
        Started with this
        Many careful bends later, we have this. Doesn't look like much but it takes a LOT of measuring, fitting, bending, refitting
        Side tube fitted for length
        We need a U-groove joint
        Hole saw on the milling machine with a test piece. Yes, first pilot hole is in the wrong place. Needs to be 1/2 the tube diameter from the end. Who let monkeys near the mill? That's why you do test pieces. :-)
        A bunch of test fitting and angle grinding later .. voila
        Test fitting a joint on the other side
        That was enough tube for the day. Rob was looking at the C5 frame and thinking of fab needed. The existing front frame bar will stick out of our bodywork.
        I was just going to hack it off and shorten it. His idea was to cut the frame, angled towards the front, flip the piece over and weld it back on. Brilliant actually. CAD says it will work. Here's a 5 degree cut, give a 10 degree drop.
        Drops the front bar just enough to clear the body nicely and leave room for airflow. And preserves the function of "bumper".
        With stock C5 radiator and LS engine installed. I like it!
        That's it for the weekend. I'm jazzed the fab is coming along well.
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1474
          #34
          Cockpit surround is coming together
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            #35
            Getting the hang of tube notching with an angle grinder
            Another frame bar done
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              #36
              Done fab on the heavy duty body frame. That was a lot of bending, staring at the pipe, bending and notching.
              Welding is next. Fired up the Pullmax in shear configuration to cut some welding practice coupons out of light gauge steel plate drop. It goes through steel like tissue paper.
              First pass at some steel TIG. Ugly, but coming along. Rob's working on MIG at the same time.
              2002 E39 M5
              • dvallis
                • Oct 2015
                • 1474
                #37
                After a lot of practice, finally getting some Ok welds on pipe
                Started welding the frame. I'm going to need a temporary hoist over the buck once this gets any bigger
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1474
                  #38
                  Solution to manipulating the frame: we built a gantry
                  Good preparation is a key for better welds
                  Gantry assisted welding. Freehand overhead
                  Always easier welding on the table
                  Need to mod the front of the base frame soon for the body frame to fit properly
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1474
                    #39
                    Hey Everyone
                    I owe you guys an update. Life got interrupted by Drama, but I'm back. Here's the latest:
                    Testing fit of the body over the C5 frame with left front quarter tube frame. Perfect.
                    Right front quarter, work in progress
                    Right front quarter done
                    Nose needs to drop. Knew this already from the CAD. Time to commit:
                    Original nose
                    5 degree cut, flipped over gives us a 10 degree drop. CAD says this is what we need.
                    Welding prep
                    Plug welded backing plates for part of the seam welds
                    Nose in progress
                    More to come ... every week from now on.
                    2002 E39 M5
                    • 2mAn
                      Señior Mod
                      • 20814
                      #40
                      PLEASE!! I love all of this
                      Simon
                      Current Cars:
                      -1966 Lotus Elan
                      -1986 German Car
                      -2006 Volkswagen Jetta TDI
                      Make R3V Great Again -2020
                      • dvallis
                        • Oct 2015
                        • 1474
                        #41
                        Update
                        Frame welding complete. Getting pretty good at TIG
                        Had to further chop the b-pillars so the body frame would sit level
                        Perfect
                        Will fab mounts for the frame next, think about triangulation points then get back to tube bending
                        2002 E39 M5
                        • dvallis
                          • Oct 2015
                          • 1474
                          #42
                          Disconnected the suspension and blocked frame to ride height. Looking good
                          2002 E39 M5
                          • dvallis
                            • Oct 2015
                            • 1474
                            #43
                            Fabricating nose section
                            Tungsten has to be SHARP for thin metal welds
                            Not terrible
                            Fixed a blow through
                            Getting there
                            2002 E39 M5
                            • dvallis
                              • Oct 2015
                              • 1474
                              #44
                              Nose mostly finished. Couple of cross braces left to add
                              2002 E39 M5
                              • tomstin
                                • Mar 2015
                                • 568
                                #45
                                Progress! Thanks for the update.
                                2004 525i Manual - 1985 325E Coupe Manual
