450v
  • Kevinxkrazy
    • Sep 2011
    • 531
    #61
    Very impressive work
    1984 Eta
    1987 Bagged
    1988 I
    1995 MX5
    1998 C70T5M
    2002 CL600
    • dvallis
      • Oct 2015
      • 1472
      #62
      Chopper installed. Bolted to the bench and bench tied in at 3 corners.
      Concept for attaching tube frame to rolling chassis. 1" ID tube cut in half, welded to the 0.5" OD tube frame. Tabs will be held by bolts into the 1" OD rolling chassis tube.
      Obviously I'm not using that tube. It's just some 1" ID drop laying around.
      "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
      1987 E30 3L Turbo Stroker Das Beast
      2002 E39 M5
      • dvallis
        • Oct 2015
        • 1472
        #63
        Tested some new TIG tungsten. Turned out pretty good
        2002 E39 M5
        • dvallis
          • Oct 2015
          • 1472
          #64
          Frame tab test
          We'll finish it off with a threaded marsin into the large tube, then bolt into that
          2002 E39 M5
          • Northern
            I like cupcakes & sh!tboxes
            • 5223
            #65
            Tungsten so good it creates a space-time paradox.
            Originally posted by priapism
            Originally posted by shameson
            • dvallis
              • Oct 2015
              • 1472
              #66
              Just seeing if you guys are actually reading this :-)
              2002 E39 M5
              • dvallis
                • Oct 2015
                • 1472
                #67
                Tack welded tabs holding the tube frame to chassis
                Here they are before finish welding
                Drilled each tab and the frame tube with 1/8" then quarter inch. Drilled the frame tube with 7/16" bit (technically should have been 23/64" but oh well) and installed 1/4-20 RivNuts and bolts.
                It's solid. I'll do the other side then fab the final front brackets. They'll be a bit more complex given the geometry. Once that's done I'll clamp and tack weld the nose onto the quarters.
                2002 E39 M5
                • dvallis
                  • Oct 2015
                  • 1472
                  #68
                  Getting better at welding tabs on the tube
                  Final product before adding rivnuts to the whole thing. I'm really satisfied with the way everything is lining up. Nose mates nicely with the front quarters and everything sits on the chassis correctly.
                  Waiting for more 1/4-20 rivnuts and a 25/64 bit from Amazon.
                  2002 E39 M5
                  • dvallis
                    • Oct 2015
                    • 1472
                    #69
                    Nose tabs
                    Welding prep. Yes, really
                    TIG welding is great
                    We're gonna need a bigger boat (i.e. I need a bigger welding table)
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1472
                      #70
                      Front end mostly complete. Talking to a shop about a bigger welding table tomorrow.
                      2002 E39 M5
                      • tomstin
                        • Mar 2015
                        • 562
                        #71
                        How is this project going? I'm sure it's hard to wrench, photograph and document. Best wishes!
                        2004 525i Manual - 1985 325E Coupe Manual
