Newman's E30/Skyline swap thread
  • newman
    • Mar 2007
    • 1159
    #61
    The inlet to fuel pump has to be below the sump of the fuel cell, so I don't have many mounting options. I'm not lowering my car a lot (because low cars fucking suck) so I think it will be OK. It doesn't sit much lower than the rear dif.
    1987 325is: 495whp/400ft-lb
    UPDATED 03/12/10!: RB26DETT Swapped E30
    • newman
      • Mar 2007
      • 1159
      #62
      If it's really close to the ground and concerns me, I'll build a protective cage for it.
      • e30slut
        • May 2008
        • 793
        #63
        you could cut into the tire holder and tuck it about 2-3 inches. just an idea.
        a speed bump would take that off with pleasure.
        • etxxz
          • Feb 2006
          • 2085
          #64
          soft lines cmon man i'd expect you to hard line it with some thick walled 3/8 316SS lines rated at 7500psi ; / i'd move the pump for sure. put it on the side if anything, not the bottom. or put it by the stock fuel filter location.. probably better. gl
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • newman
            • Mar 2007
            • 1159
            #65
            The sump hangs below the tire well, so if I were to move the pump up, it would be way too high.
            I can't put it at the stock fuel filter location because it's too far from the tank, and in order to get there the lines need to go up really high. Keep in mind the inlet to the pump needs to be gravity fed...
            And I thought about hardline, but -8 stainless tube is kinda hard to bend by hand.
            • newman
              • Mar 2007
              • 1159
              #66
              I'll let the pix do the talking...
              • E30QC
                • 214
                #67
                I read your build site today... opening line: I hate bmws'
                Strange... Strange indeed, your right though, hondas' are much more attractive... yuck
                p.s. how many civics do you see still running from the mid-eighties? Thats' right... there made out of coke cans...
                • ColdAccord
                  • 5926
                  #68
                  are you keeping the awd?
                  Originally posted by blunt
                  • newman
                    • Mar 2007
                    • 1159
                    #69
                    shut up
                    • newman
                      • Mar 2007
                      • 1159
                      #70
                      this weekend I pulled all the fuel lines and brake lines out, painted the holes I had drilled for the mounting hardware. I also added some mounts for the brake lines.
                      While i was under there, I had to put por 15 back on places where i had welded the seat rails in, because it had burned off.
                      I also installed the oil restrictor that I made in the block.
                      Lastly, I made brackets from 3/8 304SS to mount my new bigger front brakes, which arrived today (so did my wheel studs... FINALLY)
                      Here are the new rotors (foreground) old rotor (background) and new 6 piston differential bore caliper.
                      • newman
                        • Mar 2007
                        • 1159
                        #71
                        WHEEL STUDS INSTALLED. Love the "extended stud look"
                        New caliper on new bracket with OLD ROTOR
                        for reference, here's where the old caliper sat:
                        • 87e30
                          • Jul 2008
                          • 5676
                          #72
                          You have to be kidding.
                          I just hate everyone.
                          No need for discretion.
                          • E30QC
                            • 214
                            #73
                            Am I only the one to read his webpage?
                            • TheB1G Lebowski
                              • 593
                              #74
                              No i read it, and loved all pages. This is great, an atrocity...kinda. But ballsy and i love it. Im an wankel at heart and would to see a sweet FD3S motor in single turbo trim would be great.
                              1989 325i - sold
                              1987 RX-7 Turbo II - sold
                              1990 325i
                              • JTinFL
                                • Jul 2009
                                • 12
                                #75
                                Nice build. The RB26s can be laggy. Good thing you will be 1000 pounds lighter. ;) GT35R is a good choice though, I would go with the smallest AR possible.
