Rust goes both ways
    I think you guys are missing the point of "Projects" and the need for a beater for DD comuting. Its not gonna see the track, it just needs to get him to and from. If it all ends up pink and glory holes in the door, thats his perogivite. Maybe hes moving to SF... No one knows! We all know that car is dead really, so help the guy out huh? Don't hate, Motivate!
    GO PINK WITH GLORY HOLES!!!
    DAMN CASTRO CARS!!!
      I'm not very good at this whole being a mechanic thing, it takes me way to long to get anything done.
      Did get the brake lines loose!
      Trying my damnedest to get ready for the diff.
      Does anyone know how to get the ebrake cable loose?
      I can't get the top passenger side bolt out that holds the diff to the subframe. Its quite hard and I think I may have pulled something. Oh well so much for one night.
      1992 318ic
        DAMN CASTRO CARS!!!
        Its not cheating if you don't look them in the eyes.
        1992 318ic
          i am sorry for you, so I'll try to help.
          As for your current predicament have you broken the bolt free yet or not? box end wrench is the only way to go, with another wrench looped on for extra leverage. Once you have it loose you should be fine, keep pressure on the diff with the jack so you're not putting all the weight of the diff on that bolt. I always leave the big bushing bolt for last to hold the thing in place til I'm ready to drop it.
          As for the ebrake cable, where the cable goes in to that do-dad there's a pin that you have to punch through, can be a pain in the ass sometimes cuz you'll have to brace the do-dad against something to give it a decent whack with a hammer and punch. The part that pivots is like a sheath over this and will have to be rotated away to expose the pin that's gotta go.
            Ah its a lot like my M then. Now the part that gets me is the cable its self isn't screwed into anything is it? If not then it is rusted to the hub. Also that do-dad is stupid rusty as well.
            1992 318ic
              Holy shit, do yourself a huge favor and just make the thing safely/reliably drivable. Then daily drive the shit out of it until it rusts away and then sell the thing for parts.
                Got the diff out! I may have dropped it about 6 inches I hope it'll be ok. I'm not going to clean it up and paint it in the same stylish way as my subframe as I'm afraid its covered in structural rust.
                The ebrake cable was rusted to the hub and the slider mechanisim was rusted together so I said fuck it, its not like I live in hilly Kentucky or anything... er shit. If anyone wants to donate a pair I'd be happy to get them then wait months and months to install them.
                I loosened the subframe nuts expecting it to just drop out. No such luck. I read a post on e30tech where one of their bushings was already split and they just wedged the other out but I have no such luck. Any suggestions?
                I think I need another one of these
                1992 318ic
                  Oh this is exactly what I plan to do. I've always wanted an e30 so why not get a bad one so I can get it out of my system?
                  1992 318ic
                    Today I had two eager volunteers. Bruce and Brandon. Little did they know what they were getting into, bushings. Out with the old in with the new.
                    First we start off with a picture of my differential
                    This has nothing to do with anything at the moment.
                    Out with the old subframe. What a bitch. In the other post when I was talking about the subframe not dropping out I didn't know there was brackets holding it on. Got 3 out and stripped one. Not bad!
                    After some motivating I got the last one out and then hammered away at the trailing arms until they bent and blam the subframe dropped out.
                    Its a good thing I'm replacing it because its become extremely blurry.
                    This is the bent part of the subframe that caused my wheel to have excessive positive camber.
                    Got the trailing arms off. Also my old stuff had abs and my new stuff does not so no more abs.
                    Quick run down of things I'm not going to have:
                    ABS
                    Ebrake
                    Dignity
                    Cleaning up the rust for now
                    Out with the old
                    "Hi I'm bruce" says bruce
                    Trying to take apart the brake assembly
                    One of those damn bolts that holds the rotor on is stupid stripped out and now has a broken easy out in it. Its going to have to go to a shop eventually.
                    This use to be car. Also I look silly without a beard.
                    Fancy bushing tool. OEM BMW.
                    Air tools
                    Old bushings. How am I suppose to get these out? I know, my neighbor Karl.
                    One Karl later and they are out. Easy as that!
                    $15 a piece.
                    I put the trailing arms back on the subframe and realized that there is no way I'm getting this back on the car by myself. So much for tonight
                    Time for one of these.
                    You may have noticed the quality of my commenting going downhill. That's cool but if you have any questions about how I did anything let me know I may be sober enough to answer.
                    1992 318ic
                      Ugh. I was going to put the subframe in today but I noticed that part of the old bushing had broken off in the chassis on both sides. I was able to remove one of them but I am stuck on the other side.
                      1992 318ic
                        This is like a soap opera. You know its gonna suck but you cant help but watch to see who goes into a coma! A caffeinatedsoap opera!
                        I WIN!!!!
                        DAMN I CRACK MYSELF UP YALL!!!
                          P.S. Ibuprophen and Coronas dont mix sir... Ask your nurse nieghbor Karl.
                          Now Vicoden and Jim Beam = WOOOOOOO!!!! We got a PARTY!
                          DAMN PUBLIC SERVICE ANNOUNCEMENTS!!!
                            I got it out. Lots of drilling. Lots and lots of drilling. Also with the help of some friends got the subframe mounted. Forgot those pesky brackets though. I'm going to put it all back together then put a jack under the subframe and mount them.
                            I'm beginning to not like this car. This isn't fun anymore. Something is in the way of my progression every step of the way. It does feel good to overcome it though. God I want this beast to run its killing me, more than the ibuprophen and corona.
                            I've got one Corona left by the way. Its going to be my victory Corona.
                            1992 318ic
                              I'm moving on to the hard stuff
                              800mg Ibuprofen from when I wrecked my motorcycle.
                              1992 318ic
                                That car is too high.
                                1992 318ic
