Rust goes both ways
  • caffeinatedsoap
    • 360
    Rust goes both ways
    I was looking for a beater for school as I have to drive 40 miles a day for class and I hate to put that kind of millage on my M as its already near 180k.
    Then I found a nice little e30 in the rust belt. This thing is rusty. I swear half the diff has to be rust and the ebrake was rusted to the inside of the rotor so bad that we had to use a truck to pull it up the trailer to get it home and that still didn't break it free. Also it may have been in a slight wreck that will require me to replace the rear trailing arm.
    But... it was $350, with a clean title, who can say no to that? (not that I haven't already spent that much on brakes and battery, lets not get started on rear suspension)
    White leather interior, mystery wiring, 10 different kinds of spiders and half the original tool kit.
    I plan to do awful unforgivable things to this car.
    Before I do that though I need the damn thing to drive correctly. The rear wheel is cockeyed to shit so I'm starting out by replacing the rear subframe.
    1992 318ic
  • theox69
    • May 2008
    • 1732
    Sounds like quite a project you've got yourself there!
    When you said your M, I immediately assumed e30 m3.
    ...and then I saw the e36.
    That car should have most of its parts transferred to the e30.
    Then it would make a good daily!
    you can have the keys to my hunk of 20+ year old West German steel when you pry them from my cold dead fingers.
    • caffeinatedsoap
      • 360
      So I scored a rear subframe and trailing arm from a guy who actually pointed me toward this forum and who knew a friend of mine.
      Sweet $100 how could I go wrong?
      Needs new bushings and some paint to prevent it from looking like my current suspension.
      Paint I can do!
      I was feeling very manly after painting car parts so I decided to try and remove the diff.
      Jacking up the car was terrifying as all the jack points are rusted out. I put the factory jack on the jack points and started cranking. The jack went up but car did not. After some persuading I got the rear on jack stands screw the front.
      More to come when I'm less lazy.
      1992 318ic
      • caffeinatedsoap
        • 360
        Too much rust on the e30 and I like the e36 way too much.
        1992 318ic
        • caffeinatedsoap
          • 360
          Quick post. This is out of order by the way.
          First step, remove exhaust. Being as it was half removed already I decided to go for it.
          1992 318ic
          • caffeinatedsoap
            • 360
            Found that exhaust leak
            1992 318ic
            • Eric Giles
              • 1068
              I admire your intentions, but that car just has too much rust to be worth all of the hassle. But I do wish you the best of luck with it!
              Eric Giles
              '20 M2 CS
              '04 M3
              '11 X5 35D
              '87 325is
              '91 325i Sport
              There are few things more expensive than a cheap BMW...
              • TopOfTheLine89
                • Jun 2007
                • 919
                I went and took a look at this one 2 weeks ago and thought the same thing. Apparently the guy had bald tires in the rain and slid the right rear tire into something hard. Good luck with it, your a brave man.
                97 tacoma 5 spd 4 cylinder
                2001 330ci 5 speed
                83 733i 5 speed, (FS)
                • whiltebeitel
                  • Apr 2007
                  • 2098
                  You kick ass. This is perfect for what you are doing.
                  '89 325i track sloot
                  '01 530i daily
                  -Enginerd
                  • 87e30
                    • Jul 2008
                    • 5676
                    I'm sorry.
                    I just hate everyone.
                    No need for discretion.
                    • e30slut
                      • May 2008
                      • 793
                      WTF? so poeple soak their E30's in salt/acid-water now?
                      • caffeinatedsoap
                        • 360
                        Don't be sorry, be rusty!
                        1992 318ic
                        • caffeinatedsoap
                          • 360
                          Just go the axles loose. Also fuck spiders. I hate spiders.
                          1992 318ic
                          • ColdAccord
                            • 5926
                            meh. since you're down there, I would have just paid $1k for something that was rust free but needed work. At least then the end would justify the means. With a rusty chassis, you can sink as much as you want into it maintenance wise. You still won't get anything out of it
                            Originally posted by blunt
                            • caffeinatedsoap
                              • 360
                              Rust me, it'll work out.
                              1992 318ic
