My E30M3 S14B23 -> S50B32 -> RB26DETT. We are alive!! p.28
  • Mr. Horsepower
    • 386
    #406
    Hello mates! Not much have been done since last time. I have, as some of you have read, moved to another place i Norway. So it was time to move the car along with me. Me and my mate got together and rented a garage, and it was time to move the car.
    I started off by getting the car ready to me moved. This was to put on all suspension and stuff like that to get is as a rolling chassis. I also had to get the tires mounted on the Work wheels.
    So this time it is just some photos of what the final product might look like in the end.
    I'm worikng at Volkswagen now, and I borrowed the new Caddy Maxi 4-motion for the moving job.
    After some man hours this was the result. I'll let the photos speak.
    Caddy is packed with the tools, parts and what not.
    Off we go...
    After 2.5 hours on the salty Norwegian roads, it was time to give it a quck wash.
    And finally in it's place in the new garage.
    1987 BMW E30 M3 RB26
    2016 VW Polo 1.2 TSI R-Line
    Originally posted by 5spoke
    Fucking norway and your sick clean ass e30's! Yes i am yelling!
    • Mr. Horsepower
      • 386
      #407
      Originally posted by Wschnitz
      This thread makes me question myself what I want to do with my E30 every time.
      Glad that I can provide motivation :)
      Originally posted by blck325is
      Just got caught up...and I'm just wow. Properly amazing and well documented build. Keep up the great work.
      Thanks. Glad to hear you find it entertaining :)
      Originally posted by Sade
      Now i have seen pics, hole car whit those rims...To me sooo epic
      Thanks!
      Originally posted by pandaboo911
      This is probably nitpicking but you should mount your oil cooler with a long screw and standoffs. Some oil coolers fail from vibration and your seems to be mounted directly. The long screw will compress the cooler from both sides preventing failure where the cooler is brazed together.
      That or put some neoprene washers in between cooler and chassis.
      I'm talking about the blue spacers in this pic:
      I love your attention to detail though.. mismatching screw color. Awesome.
      Can't wait to see this thing running!
      Thanks for the info. Will take action regarding this! :)
      Originally posted by e30onBBSs
      just set your engine bay as my background! That thing is siick
      I'll drink to that!
      Originally posted by FreedomM3
      How in the world did I miss this thread?!
      Get out of my head. This entire build has been what I wanted! Except the RB, any particular reason you went with the RB instead of something like the 2JZ?
      Anyways great work! Please keep posting pics
      1. Because every one else is having 2JZ.
      2. Because 2JZ is to straight forward.
      3. RB26 have the best stright six sound there is.
      4. 2JZ have to much newton to get it road legal in Norway. We have a limit of 330hp and 355nm in the E30 chassis.
      • FreedomM3
        • Aug 2015
        • 191
        #408
        Well, I'll do my best not to be envious of your build as it is what floats in my dreams.
        I'm originally a toyota guy so I am naturally doing the 2JZ once the chassis is complete. I am totally digging the new wheels! Looks awesome!
        Keep up the good work and we dont mind you pic whoring!
        Our RestoMod Diary!
        El Mustache De La Resistance!
        • CorvallisBMW
          Long Schlong Longhammer
          • 13039
          #409
          Those new wheels look great!
          • Mr. Horsepower
            • 386
            #410
            Hello fellow members. I have not been nice about the updates. I have been doing a lot of work that does not show in photos. Small tweaks here and there. Have been making a lot of progres though. So let's let the photos do the talk.
            I got a set of Mine's rocker cover baffle plates. These will prevent oil beeing thrown out into the catch can.
            I have been building new AN6 fuel lines, they are not finished in the photo. Need some clamps and tidying up.
            The steering knuckle got an aluminium bushing.
            Went with AN fittings from fuel pump and all the way to the fuel rail. Nice, tidy and expencive..
            Made a heat shield from aluminium and covered it with gold heat reflective film.
            Found a new place for the brake fluid reservoir
            The two AN12 breathers
            Went with an stand alone oil filter for the turbo. A must for a good ball bearing turbo
            AN lines and engine mount
            Got a turbo beanie for the Borg Warner, wide band lambda and exhaust wrap
            Gapped the spark plugs and installed the Benchmark coils
            Received the MAXX ecu plug and play for R32GTR
            Started wiring the engine up. Plugged in the Wiring Specialities harness and so.
            Started by pluging in the stock ECU and twisted the key to prime the oil. Went on turing until oil came out of the turbo turn line. But noticed the fuel pump did not run. I then noticed I had forgot to put on a wire that needed permanent +. Fixed that an then the fuelpump run. Primed fuel into a bottle to get clean fuel. Stated the car on first try with the stock ecu, but it did not run well, missing both MAF's and labda.
            I connected the MAXX ecu, and calibrated the TPS.
            Then, guess what?
            • Nisse JƤrnet
              • Aug 2013
              • 1221
              #411
              Nice man! :D
              E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
              E30 M50 6 spd 764whp @ 24psi.
              E30 M20 6 spd 675whp.
              • Tougerunner01
                • Apr 2014
                • 237
                #412
                [emoji119]
                Sent from my SM-G920P using Tapatalk
                • Loupoz
                  • Feb 2012
                  • 166
                  #413
                  Such progres, much wow!
                  Big GZ
                  My 325I Mtech1 S54 Build
                  • 2mAn
                    SeƱior Mod
                    • 20982
                    #414
                    way too long without an update....
                    Simon
                    Current Cars:
                    -1966 Blue Boat
                    -1969 Red VW
                    -1986 White BMW
                    -2006 Green Thing
                    Make R3V Great Again -2020
                    • AusScare
                      • Jun 2014
                      • 220
                      #415
                      Awesome update!
                      '90 318is
                      • CorvallisBMW
                        • 13039
                        #416
                        Congrats on the startup! It sounds perfect, nice and smooth
                        • Mr. Horsepower
                          • 386
                          #417
                          Hello!
                          I'm so sorry that I have not been able to update. I was going to do it now, but Photobucket is down for maintanance.
                          I have driven the car 7000km this summer, and found some issues that I need to take care of in the winter.
                          I can try to get a big big update during this weekend. Think I have time on sunday.
                          Till then...
                          • Sh3rpak!ng
                            • Jan 2014
                            • 2667
                            #418
                            where dem pictures at?
                            Shadetree30
