Budget M42 turbo build
  • Schnitzer318is
    • Jan 2008
    • 2057
    #76
    Now you got me all excited...
    Hopefully that added diameter will grab as you said. I'm interested as I've wanted to do an m20 conversion but hadn't been able to find as much info as I wanted on it. I've driven a car with the conversion done though and it was nice.
    "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
    91 318is Turbo Sold
    87 325 Daily driver Sold
    06 4.8is X5
    06 Mtec X3
    05 4.4i X5 Sold
    92 325ic Sold & Re-purchased
    90 325i Sold
    97 328is Sold
    01 323ci Sold
    92 325i Sold
    83 528e Totaled
    98 328i Sold
    93 325i Sold
    • gearheadE30
      • Jun 2007
      • 3734
      #77
      haha well I suppose I'll find out soon enough. Even if it doesn't work out, though, there are a lot more upgraded options out there for the M20 than the M42, at least that I could find.
      Also, the M42 actually came with 2 different versions of the Getrag 240. The gear ratios are the same between the two, but later ones got a 15mm pilot bearing (up from 12mm) and a slightly different shift mechanism. I'm not sure if there are any other differences though.
      Project M42 Turbo
      • e30guydownunder
        • Jul 2008
        • 874
        #78
        teh 228% has a 6% increase in Surface Area over the 215, but as the area is also further out, this should boost its torque capacity even further. But as you said upgrades are plenty available.
        I picked up a 240mm M3 clutch/flywheel kit inadvertently with an M42 purchase. I was happy!
        Making some nice progress there.
        Schnitzer, What more info do you want about the M20 swap?
        - Chris
        Project M42 - 255 @ 19 psi
        • gearheadE30
          • Jun 2007
          • 3734
          #79
          Does the M3 flywheel fit int he e30 getrag 240? I thought the bell housing was too small.
          At any rate, its almost back together. I just have to bolt the trans, starter, driveshaft, heatshield, and exhaust back in :)
          Project M42 Turbo
          • e30guydownunder
            • Jul 2008
            • 874
            #80
            Nope and the mods the PO did to the bellhousing to make it fit are scary! I'm using a 260 in my build so won't be an issue.
            - Chris
            • gearheadE30
              • Jun 2007
              • 3734
              #81
              so I finally got the trans in, and what do I find? No third gear and a completely shot 4th gear synchro. Wonderful. At least the flywheel works great. And just for reference, even though the M42 and late M20 starter look the same, they aren't. You still have to swap over the pinion gears.
              Project M42 Turbo
              • Hobbes
                • Sep 2009
                • 29
                #82
                Reading this thread made me happy. I always want to keep my m42, but I don't think I have the budget to go FI. Though I will say, Megasquirt and boost does sound like a ton of fun, and m50's are heavy.
                • gearheadE30
                  • Jun 2007
                  • 3734
                  #83
                  Thanks :). Yeah, the budget is a bit more than I expected, and I estimated high, hah. It'll be worth it, though.
                  Small little update: now planning on using a Valvo 740 TIC intercooler. More surface area and thinner core, and a lot easier to mount, I think.
                  Project M42 Turbo
                  • Schnitzer318is
                    • Jan 2008
                    • 2057
                    #84
                    A list of exactly what is needed. I am always reading different things about different throwout bearings and pinion gears that made me now want to swap.
                    Also, I thought it was better to have a heavier flywheel with a boosted application to help load up the turbo and get faster spool? I could be wrong, just thought I read that somewhere...
                    Keep up the good work gearhead... you'll love the boost. Will make all the work, and ducket spending worth it.
                    91 318is Turbo Sold
                    06 4.8is X5
                    06 Mtec X3
                    05 4.4i X5 Sold
                    90 325i Sold
                    97 328is Sold
                    01 323ci Sold
                    92 325i Sold
                    83 528e Totaled
                    98 328i Sold
                    93 325i Sold
                    • gearheadE30
                      • Jun 2007
                      • 3734
                      #85
                      Here's what I used:
                      -M20b25 single mass flywheel
                      -late M20 small starter, i think only from the m20b25
                      -e21 323i throwout bearing
                      -M20b25 clutch kit
                      -The back side of the flywheel needs to be machined down so it is flat in order for it to clear the back of the engine
                      -M20 flywheel bolts
                      The starter is pretty easy to take apart, and you just have to swap the back half of the M20 starter into the front half (mounting points) of the M42 starter.
                      Also, got a new trans on the way! hopefully this one works out better....
                      I really think that's it...
                      Project M42 Turbo
                      • e30guydownunder
                        • Jul 2008
                        • 874
                        #86
                        I used:
                        E30 323i Single Mass flywheel
                        3mm Spacer between flywheel and crank
                        E30 323i starter pinion modded to fit in M42 starter (not direct plug and play like late M20 starter pinion)
                        Single mass clutch kit including the M20 TO bearing that came with it.
                        Don't forget the single mass flywheel bolts to suit.
                        - Chris
                        • gearheadE30
                          • Jun 2007
                          • 3734
                          #87
                          Forgot about the bolts; oops. Added to the list.
                          Project M42 Turbo
                          • gearheadE30
                            • Jun 2007
                            • 3734
                            #88
                            Been doing a bit of work the last few days :)
                            Project M42 Turbo
                            • Dj Buttchug
                              • Jun 2010
                              • 7686
                              #89
                              oh damnn nice set up!!
                              Turbo M42 Build Thread :Here
                              Ig:ryno_pzk
                              I like the tuna here.
                              Originally posted by lambo
                              • freeride53
                                • 11972
                                #90
                                sexsie
                                1983 Peugeot 505 STI
                                1992 Volvo 240 Wagon
