A look at things to come
  • Matt-B
    The Waffler
    • 3856
    #301
    Finally got this out
    And replaced it with this
    and added a new resistor
    • ck_taft325is
      • Sep 2007
      • 6880
      #302
      Good man ;)
      Butt hook wrench or just Superman the damn clip?
      Need a part? PM me.
      • accident
        • 7303
        #303
        I always use a flathead and press as hard as i can in the direction it's supposed to go lol. i remember reading DIYs for doing the blower and getting scared of the clip, but every time i've done it, it was stupid easy.
        Moral of this story?
        • Matt-B
          The Waffler
          • 3856
          #304
          chris I used a hook took for pulling trim and sliced my knuckle open. screwdrive and mallet for reinstall
          • ck_taft325is
            • Sep 2007
            • 6880
            #305
            :dot:
            BAM BITCH!
            Get that revenge and :D
            Need a part? PM me.
            • Matt-B
              The Waffler
              • 3856
              #306
              Ill pay someone like 50-100$ if when Im pulling my motor, to check and see/correct if i connected m50 harness to right plugs.....and sensors.
              • hi its me alec
                • Apr 2008
                • 478
                #307
                Did you reference the wire colors and a diagram when you hooked them up?
                If so, shouldn't have any problems besides the knock sensors being flipped or something.
                WTB: early e30 sedan front doors
                • DREWHALL
                  • Feb 2006
                  • 1207
                  #308
                  Why I'm glad my harness was attached to the motor when I put it in lol. I guess when I pull it to rebuild or put S50 or whatever happens I'll just label them all. Looks good!
                  • Gooch
                    • Dec 2006
                    • 1674
                    #309
                    Hey, Matt, any chance you could get me rough measurements of the two brackets for the M50 manifold? I have one but I don't know if it's the front or the rear and need to determine that so I can source the other. Thanks!
                    '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                    '87 535i - Vacuum brake conversion [SOLD]
                    '93 525iT - 5-speed swap - 320k and counting
                    '09 328xi - 6-speed
                    • Matt-B
                      The Waffler
                      • 3856
                      #310
                      I can get a better pic for you....
                      I might have wishno come over, and care crack his wire insulation, peek at wire colors, and give him some cash
                      • Jand3rson
                        • 37587
                        #311
                        Matt, I think you've got that exhaust-side engine mount on upside down, buddy.
                        • Matt-B
                          The Waffler
                          • 3856
                          #312
                          wishno's motor
                            • 37829
                            #313
                            Definitely not upside down.
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • Matt-B
                              The Waffler
                              • 3856
                              #314
                              woo woo, working on matching my wires to correct sensors now...
                              m20 coolant sensor(e34 harness brown,brown red)
                              water ecu, blue plug
                              Throttle sensor (e34 colors red yellow, brown blk, brown)
                              intake temp, next to TPS (e34 colors grey, brown)
                              02 sensor (round 4 prong plug)
                              Oil pressure, from oil housing ( single brown wire)
                              crank and cam sensor is 50 50, same color wires.
                              what colors are the ICV guys?
                              • Vtec?lol
                                • Dec 2009
                                • 3278
                                #315
                                love the work!
