A look at things to come
  • Wishno87
    • 6025
    #646
    Originally posted by Matt-B
    Look right after the o2?
    there is a flange...
    It won't work there. I have removed those headers before and I know.
    • Matt-B
      The Waffler
      • 3856
      #647
      this whole time I was told nothin will work, the ix booster, my headers, and everything has.
      I suppose Ill take my chances :)
      • LJ851
        • 7919
        #648
        It appears to be working now?
        Lorin
        The M30 is God's engine.
        • Wishno87
          • 6025
          #649
          I never said none of that will work. But my experience has showed that there are better options than the ones you have selected. I had to remove my engine mount arm and take each header out separately. Stop acting like Japandrew.
          • Wishno87
            • 6025
            #650
            What I'm saying Is the flange is In the wrong spot to be able to remove the headers without chopping it up. I have delt with that issue with those headers twice and just trying to share my accumulated knowledge.
              • 34844
              #651
              Originally posted by NitroRustlerDriver
              They restrict flow massively. Just an old low tech way of making a bend.
              A properly done crush bend won't limit flow significantly, depending on the angle of course (the tighter the bend, the worse the flow - but a shallow bend is fine). And it can be better than using mandrel sections and poor quality welds with big ridges on the insides of the pipe. I'd much rather have a well done crush bent exhaust, than a poorly done mandrel bent exhaust.
              My exhaust is a combo of mandrel bends and crush bends depending on where they are appropriate. I can gaurantee you it's not restrictive. :)
              I don't really like the rear section, the bends are in wierd places. under the trailing arm? it would be better to make the first bend directly under the subframe and hug the diff. but whatever.
              Originally posted by Ryann
              ^Slightly higher exhaust restriction=more torque!
              I hope you're being sarcastic!
