A look at things to come
  • Matt-B
    The Waffler
    • 3856
    #271
    change things up to what? I find most other wheels I like are to expensive, impossible to find, and most are boring.
    I want 16" hartge or something of that nature. And I feel 2,000$ is a bit much.
    • Matt-B
      The Waffler
      • 3856
      #272
      enjoy. decided, to screw fixing dimples on valve cover. to cold outside for drying and decided not to wait for it to dry again
      • Edev
        • 3731
        #273
        Ah so you're the one who sent me a picture text of a motor. I wasn't sure who it was. You're getting closer and closer though. Do you have a rough estimate as to when it'll be running and driving?
        M Coupe
        • White325is
          • Oct 2006
          • 5947
          #274
          Im gonna help you now by telling you that you need spacers under them there 6 bolts holding on your trigger wheel. Or when you go to start the motor, it wont turn over. Then you will be making a "why wont my 24v swap start?" thead.
          • Matt-B
            The Waffler
            • 3856
            #275
            I used washers, but should i cut the middle out of the AC pulley or something?
            Eric: Month? i still need to do my engine bay....not so much shave, as a clean and paint.
            • Edev
              • 3731
              #276
              Now that sounds good. I can dig it.
              M Coupe
              • White325is
                • Oct 2006
                • 5947
                #277
                Doesnt look like you added anything. Thats the reason why I said that.
                I figured you would have tossed in some new washers and wire wheeld them old bolts and paint the trigger wheel.
                • Jand3rson
                  • 37587
                  #278
                  Wire wheeling bolts... that I'm not looking forward to. But ain't no way I'm putting a bunch of dirty, grimy old bolts back on my shit.
                  • Matt-B
                    The Waffler
                    • 3856
                    #279
                    Yea i got some in there about same diameter as bolts. Ill double check width also...
                    got your text thanks :) just need a starter and I essentially have everything
                    I have to wire wheel quite a few things hardware wise to :(
                    • White325is
                      • Oct 2006
                      • 5947
                      #280
                      Wish I would of known. I have a started for single mass M20 flywheel sitting right here.
                      • Matt-B
                        The Waffler
                        • 3856
                        #281
                        My flywheel is a lightened E flywheel.
                        I guess you have to match the teeth up? As some are different
                          • 34844
                          #282
                          just buy new ones. I wasted an entire *day* cleaning old nuts and bolts, I could have bought all new ones for like $50 and gone to the movies or something instead..
                          • ShowStopper
                            • Jan 2008
                            • 1845
                            #283
                            i bought most of my bolts new..still need some for the trigger wheel.
                            • Jand3rson
                              • 37587
                              #284
                              Meh, that sounds like more of a pain in the ass than cleaning them. I'd spend an entire day trying to order the right quantity and size of every bolt on the engine, I'd rather just clean them. Not to mention, a total waste of good hardware and money.
                              • samiam3356
                                • Jul 2009
                                • 1901
                                #285
                                Just take the bolts with you to the hardware store and they will match them up for you. Any decent hardware store anyway.
                                You can also let them sit in purple power over night and that shit will about eat anything off them. You won't even have to wire wheel them. or at least i didnt.
                                Originally posted by Roysneon
                                $5 shipped?
                                Originally posted by MarkD
                                You are a strange dude, I'n not answering any more posts from you.
