The steering wheel wiggles without the car being on the ground?
The MR E30 Project Thread
The steering wheel will viciously go back and forth with the front wheels on the ground, or with them in the air.My previous build (currently E30-less)
http://www.r3vlimited.com/board/showthread.php?t=170390
A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsessionComment
That would have to be your fluid system then because it eliminates the wheels from the equation. The shitty part is it is not easy to test those components individually...my money is still on that pump lol.Comment
Problem was temporarily solved.
Power steering is gone for now.
Brakes arent bleeding at all. Pedal goes to the flooron the first push, and it will maintain pressure if you pump it twice in rapid succession.
Even a one second break will cause it to go all the way down to the floor. Even driving it around my neighborhood is a pain in the ass.
I really dont want to buy more new parts, but if people think the MC is bad I guess I gotta do what I gotta do.My previous build (currently E30-less)
That'll fix the power steering too...lolProblem was temporarily solved.
As for the brakes, I just replaced the front brake lines tonight and pulled the MC off to replace the seals. Usually if there is a major loss in pressure like that either one of your brake hoses has a major leak, one of the 3 gaskets on the MC itself has given out, or the MC internals are bad. I hope its one of the first two because they are cheap and easy.Comment
I cant see any leaks, and the brakes will hold pressure very well if i hold the pedal down after pumping it three times in rapid succession.
I am going to try the tracing the lines and see if I have a blockage option.
Front squirt out fluid very well. Rears barely drain out. Thats my issue.My previous build (currently E30-less)
All issues were solved.
First drive into town today to grab lunch with a fellow E30 enthusiast.
Everything went just fine. I missed speed a lot.My previous build (currently E30-less)
The bleeder screws were clogged, letting almost no brake fluid out. I could have fixed it by bleeding the brakes forever, but I decided to pull the rear calipers off, rebuild them, and soak the bleeder screws in acetone.
10 minutes later I pulled them out, cleaned em out with a tiny allen key, reinstalled everything, and the brakes bled much quicker.
I drove it to work the past couple of nights, and aside from a few small issues, everything is awesome.
Its going back in the garage tomorrow to get the interior put back together, and those few minor issues taken care of.My previous build (currently E30-less)
love your car man! love your style that you put into the car too!
Patrick - IG:niicknac
RIP 1987 BMW 325is - S50'd ZF 6-speed, flared, baggedComment
March 24th, 2013
Alright, I have a new issue. I bled the brakes, parked the car, got in the next day and the pedal was very soft again.
Rebled them, but they arent making the pedal harder. I am doing it right, with the tube/bottle and a second person.
Is my master cylinder shot? no more bubbles are coming out, just fluid.
The brakes still stop the car, but the pedal is wayyy too soft.
TIAMy previous build (currently E30-less)
I have the same problem, I am curious what you find out to solve this issue. Good luck.View my build thread. http://www.r3vlimited.com/board/showthread.php?t=287724Comment
