BBM x Schwartz x Saloons
  • Scallywagon
    • 1200
    WTF 5 Speed to Auto swap....Fuck that.
    He was taking the transmission for another one of his cars, so really he was the one who did the auto > 5-speed, I just got the left-overs.
    ( f ; _ ; )f
    • Scallywagon
      • 1200
      Okay here's an update to current. First the news/future:
      • Found an s52 package [http://forums.bimmerforums.com/forum....php?t=1501976] I am completely in love with, if everything works out this weekend I'll have it home by next week.
        • OBDII '98 s52 + zf 5-speed + all accessories (even the Key, EWS, all of that)
        • At this moment I'm looking to stay OBDII with a few exceptions for the ref out here in California; OBDI Headers, last two o2 sensors/air pump deleted and tuned DME
      As far as I know thats what its going to take for me to not throw CELs and have a CARB legal header, and in turn pass smog/ref tests, but if anyone has done the OBDII s52 into an E30 in Cali please feel free drop me any info. (like if you regret it and wished you'd swapped the OBDI while you were at it)
      Now progress on the m20:
      After the covers came off...
      This ones terrible but nonetheless dirty
      Moar dirty...
      The culprit
      After the first few cans of Breakleen
      Before the belts, as clean as I am going to have it for now (due to s52)
      And then there was this
      Contrast
      And anyways
      More pictures to come because its more put together now (the m20) and I replaced the thermostat too.
      Have soaked the wheels in PBBlaster will have them off today
      I think I'm going to still try to finish the m20 a little further so it will sell better, I'm confident it doesn't need a new head, but what the fuck do I know
      I'M FUCKIN EXCITED FOR 24VCLUB
      Complete m20 and Tranny package are for sale please make offers
      s52 tips? inspiration? lets do it up, I'm pumped
      Soon as I figure out whether I'm buying renting or borrowing a cherry picker I'll get a game plan down so I have some direction with the swap to stay on course.
      ( f ; _ ; )f
      • einstein57
        • Jun 2007
        • 10780
        You put a new timing belt on a motor that has a 99.9% chance of being toasted? Pull the head and check the valves. Concentrated simple green and a parts brush works like magic.
        www.gecoils.com
        • Scallywagon
          • 1200
          First of all, nobody would sack up and tell me it was 99.9% so yea of course I was trying to fix it
          Secondly, nobody told me I could visually check the head/valves I was told to put it back together and get a compression test
          Lastly why is a motor that needs a new head toast? Seems I can get a new head for a hundred bucks from someone local or buy the full m20 for 350+ thats why I was fixing it in the first place because I was told it was worth it
          If its not, no biggie I'll use the maintenance parts for my other m20 and part out whatever I can of the garbage motor, and fuck the people with bad advise I guess.
          ( f ; _ ; )f
          • Schnitzer318is
            • Jan 2008
            • 2057
            ^I think what he meant to say was to pull the head since you are there. It's a simple thing to do and then you know if the head is good. Plus you can do a head gasket at the same time which is almost always a good idea when you buy one of these used anyway, unless of course you know it's history really well.
            Another test is to put the new belt on and see if you can turn the motor over smoothly by hand with a 22mm wrench on the crank bolt.
            "A good memory for quotes combined with a poor memory for attribution can lead to a false sense of originality."
            91 318is Turbo Sold
            87 325 Daily driver Sold
            06 4.8is X5
            06 Mtec X3
            05 4.4i X5 Sold
            92 325ic Sold & Re-purchased
            90 325i Sold
            97 328is Sold
            01 323ci Sold
            92 325i Sold
            83 528e Totaled
            98 328i Sold
            93 325i Sold
            • Scallywagon
              • 1200
              That makes more sense
              How many revolutions am I looking for on the crank? will I know when to stop? what is not "smoothly"?
              ( f ; _ ; )f
              • Schnitzer318is
                • Jan 2008
                • 2057
                You will know smooth vs. rough. You will hear it too. I usually do 4 full revolutions of the motor just to be sure everything is good.
                You have pulled the valve cover too and made sure none of the rocker arms are broken or any cracks on the top side of the head? Have someone turn the motor for you (by hand) with the valve cover off and you will be able to see the arms moving to check that everything is operating smoothly.
                Of course I still think you should pull the head and do a head gasket change. Makes it very easy to rebuild the head as well. It's not expensive. I spent $400 buying a head, having it dipped (cleaned), clearanced at a machine shop, buying the timing belt kit (waterpump, etc), new head bolts, and buying the head gasket kit to fix a head that was damaged on a car I bought. Timing belt had broken.
                91 318is Turbo Sold
                06 4.8is X5
                06 Mtec X3
                05 4.4i X5 Sold
                90 325i Sold
                97 328is Sold
                01 323ci Sold
                92 325i Sold
                83 528e Totaled
                98 328i Sold
                93 325i Sold
                • Van Westervelt
                  • 9365
                  Its Schwarz. No 't'
                  • einstein57
                    • Jun 2007
                    • 10780
                    Wasn't trying to come off sounding like a jerk. With m20's the head is 90 of the value. Most heads need to be refreshed at around 200k miles anywho. Chances are the valves are slightly bent and need replacing. I'm sure rotating the block to TDC and then the head to TDC seperately was not to good for the valves either. When the head is pulled you can pour gas on top of the valves and see if it is water tight. Or you can take it to a machine shop for a leak down test. They can also mill a thou off for cheap since a 20 y/o head probably does not have a completely flat surface. I took apart my head and dropped it off at a machine shop. For $120 the hot tanked it, decked and diamond surface finished it, did a 3 angle valve job, re cut the exhaust seats, and assembled the head.
                    www.gecoils.com
                    • Scallywagon
                      • 1200
                      Okay hand cranked myself into disappointment.
                      Buttoned it all up and turned it over for the hell of it, and got nothing. So now I'm going to just pull it and back burner it until my s52 is done
                      I'll pull the head off and take a look at it all, and take it to a machine shop and get a new head gasket before I sell it off
                      Also I know its got no 't' but I can't edit forum titles haha
                      ( f ; _ ; )f
                      • Scallywagon
                        • 1200
                        So here's my plan of attack for the swap:
                        • Disconnect the motor from the engine bay
                        • Buy an engine stand
                        • Rent a picker
                        • Pull motor and stand it
                        • Drop the transmission out
                        • Pick up the s52
                        • Rent another picker and pull the s52 off the truck and drop it right into the E30
                        • Install the swap
                        • Get DME tuned
                        • Get/Install OBDI headers
                        • Profit
                        • Get Boners
                        Any input?
                        ( f ; _ ; )f
                        • einstein57
                          • Jun 2007
                          • 10780
                          How much do they charge to rent engine hoist? I was thinking of just getting a $100 one at harbor freight.
                          www.gecoils.com
                          • Schnitzer318is
                            • Jan 2008
                            • 2057
                            That's what I did... makes life much easier. Used it to pull an m20 and 2 heads with intake and everything attached. Definitely easier than standing on the strut towers trying to lift the manifold/head assembly yourself... I've done it that way too (at the yard).
                            91 318is Turbo Sold
                            06 4.8is X5
                            06 Mtec X3
                            05 4.4i X5 Sold
                            90 325i Sold
                            97 328is Sold
                            01 323ci Sold
                            92 325i Sold
                            83 528e Totaled
                            98 328i Sold
                            93 325i Sold
                            • Scallywagon
                              • 1200
                              its only like 150$ for the perfect hoist that folds up and shit
                              But its only 28$ to rent it all day
                              so I figured if I'm only doing the pull and drop for now I'll rent and when I get a motor for my bbm I'll buy one and be covered
                              ( f ; _ ; )f
                              • einstein57
                                • Jun 2007
                                • 10780
                                There is a guy on craigslist renting one for $20 a week.
                                www.gecoils.com
