BBM x Schwartz x Saloons
  • Scallywagon
    • 1200
    #61
    Had a seized piston on the front driver caliper AND missing an outside pad... did a sort-of budget rebuild on it, and threw new pads/rotors/sensor on, cleaned everything up, bled the front calipers out then bled the whole system with OEM brake fluid.
    Aside from needing the pads to get seated the brakes are on fuckin' point now, w00t!
    Found a fuel leak(just tightened the clamp), coolant leak, and oil leaks, gotta love an M20~
    Front Strut, TO Bearing and 2 RW Bearings up next...
    ( f ; _ ; )f
