DIY paint job. Done right. Hopefully
  • FredK
    • 14761
    #76
    Sweet work man!
    I'm sorta working up the courage to try something like this myself!
    • e304me
      • Feb 2006
      • 1374
      #77
      you can see more details of my car at http://tenhulzenautomotive.com
      ok so besides getting frustrated with the fender I filled the antenna hole today.
      Yeah, I had to much wire speed going on the welder. You have to do it tack by tack to make sure not to warp the metal. I cooled it down with a damp paper towel every couple tacks
      • e304me
        • Feb 2006
        • 1374
        #78
        So yesterday I sanded the bumper, removed the rest of the trim, and sanded it to get it ready for SEM trim paint.
        I will probably take it easy with the sanding today, my back was killing me yesterday! Probably start removing the windows and such, and getting the doors ready. Well I still want to find a door an fender that are dent free.
        I was going to replace all of the window trim, seals, ect but that stuff is SOOO expensive. It would be well over 500 for all of it, maybe even over 1000
        • e304me
          • Feb 2006
          • 1374
          #79
          I was at a car show for most of the day but I used glazing putty and resanded the dents I have fixed thus far and picked up some parts that were all over the garage
          • e304me
            • Feb 2006
            • 1374
            #80
            today I block sanded the original paint on the unibody, and painted some trim pieces. I hope to shoot the primer on thursday. Still have a lot to do before then
            • e304me
              • Feb 2006
              • 1374
              #81
              also I think i've decided on mugello red for the color. Its in between brilliantrot and henna
              • e304me
                • Feb 2006
                • 1374
                #82
                Dont know if anyone is still following this or not, but today I got 95% of the booth done, my filters didnt get here so I am not going to be able to prime till monday though. I still have some other things I can work on.
                I still have to block the right side of the unibody
                remove the undercoating from the rear valance
                block sand both fenders
                finish up with 220 grit on one of the doors and do the drivers door
                also scuff the door jams
                Then just, cleaning, masking, and priming
                Then block sand again and paint. School starts on the 20th down in California, I think I will kind of be cutting it close!!! I will probably start painting next sunday.
                • Sir Young
                  • Jan 2010
                  • 46
                  #83
                  Keep up the work, and keep the pictures coming! =]
                  535is
                  • e304me
                    • Feb 2006
                    • 1374
                    #84
                    yeah I will post some pictures tonight.
                    so far today I have gotten 1 fender and part of another ready for primer. The one I am working on now is a bitch because it was painted with a clear coat and the clear is starting to bubble so i have to sand ALL of the clear off. More labor intensive than you think.
                    There were a few dents on them but I was able to just tap them from the backside and add a touch of sanding to get them flush. No bondo needed!.
                    • ortholithiation
                      • Dec 2009
                      • 181
                      #85
                      Sounds like you are on the right track. You should check out my thread in body and paint forum. I'm just finishing the cut and buff and probably did what you are doing now.
                      This was my first time DYI job, but I had a lot of help.
                      IF YOU USE ISOCYANATE paint or anything with a hardner you MUST MUST MUST wear a respirator. Trust me. You will covalently link your lungs with carbamates and ureas.
                      325is bodywork.
                      • e304me
                        • Feb 2006
                        • 1374
                        #86
                        looks good man. I am having second thoughts about spraying it myself, but I already made the booth and bought a gun so i am going through with it.
                        I got a great mask off of ebay that is full face and has a hookup for an air line so you are always getting fresh air
                        • e304me
                          • Feb 2006
                          • 1374
                          #87
                          I am still chugging away at this, I have some stuff in primer, I will try to post an update tonight
                          • e304me
                            • Feb 2006
                            • 1374
                            #88
                            I took some pics tonight but they came out like ass. I have everything primed and have started wetsanding. I will have to reprime some sand thrus then re wetsand those areas and paint!
                            • E-Thirty
                              • 1331
                              #89
                              When you welded the filler for the antenna hole, did you paint the other side(inside trunk) or protect it in any way?
                              Do you feel like something is trying to penetrate your butthole?
                              • e304me
                                • Feb 2006
                                • 1374
                                #90
                                Yeah I used some anti corrosion primer on it
