I did, but as stated already, the sheet metal is very thin and is extremely hard to work with. All I can say is, resist the urge to twist and bend the brackets back and forth until they snap off.....it WILL deform the thin sheet metal and make more work for you later.
Not perfect by any means, but all I had was a grinder. My welding experience goes no further than being able to booger-weld two pieces of metal together, so I didn't cover all of the holes; I'll probably regret that later, but welding just was not a viable option for me considering the flimsiness of the metal in the bay.
I used Straightline body filler by POR-15 to smooth over the grinding and regular POR-15 over the (little) rust spots I had......highly recommend their stuff, by the way.....both the filler and rust preventative are a little expensive, but are among the best out there.
