Eta-to-M50: Build thread
  • travis816
    • 828
    #316
    Originally posted by cramer
    I've seen some great work come from a spray can. It's all about prep, the process and the finish. Make sure to wet sand the color and each coat of clear. The nice thing about the engine bay is it's not a flat panel like on your exterior so minor imperfections won't catch your eye.
    That is correct, but only wet sand inbetween the base coats. dont wet sand the clear untill you done with your 3 or how ever many coats. Perferable use 1000 grit when sanding inbetween base coats. and i highly recomend this because it willl give you the look that your going for.
    88' m3
    91' 318is
    • MoparJ
      • May 2007
      • 258
      #317
      Nothing wrong with spray paint at all; I'm a rattle-can commando, myself. :) As stated, it's all in the prep and application (which doesn't necessarily mean following the directions on the can, either).
      Degrease and clean, initial sand, good quality high-build primer, staged sanding, two medium-to-heavy coats of paint, staged sanding again, good quality ceramic clearcoat, fine wet sand or polishing compound.....good to go. I've done engines, engine bays, wheels and brakes for years using this method......works great.
      Jason
      • M42Power
        • Dec 2009
        • 519
        #318
        Is there any factory airbox that you can use with a 24v?
        Originally posted by kendogg
        Don't know, but the E90 wasn't designed from the ground-up intending to be a racecar like the E30 was.
        OG RACECAR
        • Jand3rson
          • 37587
          #319
          I'm not sure, I'll just be using a cone filter with some kind of enclosure around it, not sure yet. That's kind of last on the list.
          • White325is
            • Oct 2006
            • 5947
            #320
            I got ya. :)
            Old trunk seal and a piece of 1/8 inch metal. The seal holds it in place and works great. I have a bunch more pics I can post if you want. Just a pain from my phone. That setup was in my 87. I have a different setup that's in my 91 I can post when I get home..
            • BUDNUNTA
              • Apr 2005
              • 996
              #321
              Ive seen the e34 and e30m3 airboxes used, do a search theres a ton of pics and info
              I think the e34 looks best
              We're out there in here.
              • ck_taft325is
                • Sep 2007
                • 6880
                #322
                Or, KAMotors carbon fiber intake/shield setup.
                Need a part? PM me.
                • Jand3rson
                  • 37587
                  #323
                  A little bit of a hiatus there, but things are back underway!
                  First, most of the gaskets and seals to put everything back together are on their way (thanks, blunt). I'm also picking up a new valve cover, and I'm planning to have it, the oil filter cover, and several other parts such as the engine arms powdercoated in the same mirror silver as my wheels.
                  This weekend, I also picked up the midsection-> back of an E36 M3 exhaust with the muffler, so once I order my headers, all I'll have to have built for the exhaust is the section between the headers and the joint of the M3 section.
                  Engine bay work is pretty much done, I'm working on a way to hide the harness for all of the lighting and the ABS module that runs down the inner part of the driver side fender without extending them, and I think I've got something figured out. Then I just need to paint.
                  From there, once I get my tranny resealed, my clutch ordered and installed, and engine mounts, the engine will be ready to go in! I'm shooting for completion within the next 2-3 months.
                  • ck_taft325is
                    • Sep 2007
                    • 6880
                    #324
                    Definately keep us updated, Josh. Looking forward to seeing how yours turns out and gain some genuine inspiration ;)
                    Need a part? PM me.
                    • Jand3rson
                      • 37587
                      #325
                      Just got a big package from blunt on my front porch.
                      And a box of parts, too.
                      • Matt-B
                        The Waffler
                        • 3856
                        #326
                        pictures :)
                        • Jand3rson
                          • 37587
                          #327
                          Originally posted by Matt-B
                          pictures :)
                          Of a bunch of gasket kits? You already have them in your thread if people are looking for them.
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            #328
                            No, he was requesting a picture of blunt's big package.
                            • Jand3rson
                              • 37587
                              #329
                              I had already assumed that the username/password to blunt's photobucket account was common knowledge...
                              • scabzzzz
                                Estado de mierda de encargo
                                • 6871
                                #330
                                lol @ this thread. Never seen such an uplifting r3v thread before, whilst somehows maintaining its charm of trolls and sack swingers coming together in perfect harmony.
                                Josh - I know you've been waiting for my opinion to here it is: Go to your local Sherwin Williams Auto store, or some other local automotive paint store. See if you can get them to make you up a custom schwartz single stage spray can. They're like 15 bucks a can, and you can cover some serious area with just 1 can. You probably wouldnt need more than 2 cans total to hit the whole bay. Then cut and polish it with a PC or Griotts RO. It will turn out looking pretty damn good.
