Eta-to-M50: Build thread
  • travis816
    • 828
    #286
    Originally posted by White325is
    Wax and grease remover. You can get it at a local auto body supply store. Buy a gallon of it.
    Yup, wax and grease remover us the best way to go. Then tack rag it while spraying air through the gun.
    88' m3
    91' 318is
    • travis816
      • 828
      #287
      I would also suggest, use a good primer. Preferable k38 or k38 (high build). It's so worth it in the ling run. You don't want a failing primer. And the also spray much better the a cheap primer.
      88' m3
      91' 318is
      • travis816
        • 828
        #288
        Sorry i ment or k36. witch both are a ppg primer.
        88' m3
        91' 318is
        • Holland
          • Nov 2008
          • 7204
          #289
          Looks a million times better already, I cannot wait to see how this will turn out!
          Originally posted by DEV0 E30
          • Jand3rson
            • 37587
            #290
            Second application of Bondo, leveled out and sanded with 80/150/220:
            Second application of primer, after sanding first coat with 150/220:
            That lower corner behind the ABS module is a little wonky, but I don't really care, there's going to be an intake there, anyway.
            • White325is
              • Oct 2006
              • 5947
              #291
              Thats not the attitude to have homie. Fixie fixie please.
              • erik325i
                • Jan 2005
                • 3567
                #292
                It's looking good. I'm after reading your thread, I'm probably going to shave the engine bays of both my non-M e30s when I do the motor swaps.
                Erik
                • Jand3rson
                  • 37587
                  #293
                  Thanks, man. Hoping to maybe paint this week, and then I'm probably not posting anymore updates until I start getting the engine put back together in a couple of weeks.
                  I appreciate your help up to now, but this isn't a show car. I shaved the unnecessary brackets and studs to get a cleaner look, and I'm happy with where it is now. It's an engine bay, not the exterior of the car. People will only see it when the hood is up at the occasional show or if they're checking out under the hood when I am. That area will not be visible, and it looks good enough how it is. It's primered, and I am so completely over sanding and filling and dust and sanding and filling and dust and sanding and filling and dust that I want to punch babies.
                  • MR E30 325is
                    • Dec 2008
                    • 3300
                    #294
                    My project thread is only 17 pages, and I put an S52, then an AA Supercharger on my E30, which then made around 350 rwhp.
                    This thread, and build better be good. I am not kidding, whatsoever. I want to see epicness. Or I will be sadly disappointed.
                    My previous build (currently E30-less)
                    http://www.r3vlimited.com/board/showthread.php?t=170390
                    A 2016 Toyota Tacoma TRD 4x4 Offroad in Inferno is my newest obsession
                      • 34839
                      #295
                      so what you're saying is, you don't want to come and do mine next? I have about 5 extra brackets that need to go away.
                      • Jand3rson
                        • 37587
                        #296
                        Well... maybe for you, Chris. :up:
                        • Jand3rson
                          • 37587
                          #297
                          Got some small updates, ADD and boredom got the best of me last night, and I had to go paint the intake manifold.
                          Also finished removing all the rest of the wiring from the driver side, mainly the harnesses for the lights and the ABD module, they will all be run inside of the fender. Gotta clean this area, then the bay will be ready to paint.
                          • cramer
                            • 1812
                            #298
                            Nice progress Josh :) What did you use to paint the plastic intake? Does anyone make a high heat plastic paint??
                            Chris
                            90 Corrado/91 M3/01 M5
                            • Jand3rson
                              • 37587
                              #299
                              Just DupliColor gloss black. The intake manifold doesn't even really get that hot, no need for high-heat paint there.
                              • 325ix
                                • Aug 2009
                                • 7783
                                #300
                                Looks great so far. I would love to attempt this one day.
