Eta-to-M50: Build thread
It's probably just spray on dielectric grease. You know, the stuff you are SUPPOSED to put on your spark plug boots.I have this special spray that you spray on your plugs and inside the coil boots. So that if water does get down in there it won't cause a mis fire. I will get the name of it tomorrow.
You can spray it on a light bulb and in the socket and drop the whole thing in water and nothing will happen to it. Its some cool shit.Comment
lawl.
Andrew and I just got done resealing and checking all tolerances on my new 3.73 LSD. Everything inside looks perfect, very little to no wear on anything, and all of the tolerances were well within spec. Replaced all the seals and gaskets and closed it back up, just need to put it back in now and fill it up.Comment
lawl.
Fill first, then reinstall.Originally posted by Simon SWhen a dream is a dream for too long - it becomes a fantasy..
Excellent! I'll wait for you to drive the car first, but I have a back up here just in case that one wasn't good.lawl.
Nope, everything inside looked perfect, I can't forsee any issues. I did just spend almost 45 minutes trying to get the stripped fill plug out, but I got it. My neck is KILLING me (diff was in the car), but I got the fucker. Just need to order a new one now.
But that being said, diff is in the car, axles are bolted back up with all new hardware, and that completes the whole rear end. Just need to bolt up the driveshaft and the exhaust heat shields, and the car can come back down off the jackstands onto the wheels and tires again.
At this point, all that remains is I need to order my SPAL fan, and a new Magnaflow cat with a few small sections of exhaust made, and this swap should be running/driving.Comment
I still have lots to do, and wont be driving for a week or more lol
Josh, is also doing his rear suspension etc, and did that months ago...Comment
Good for him. It would have been running a week ago if he'd paid attention when he put his crank trigger gear back on.
Lots of progress today. I filled my diff with RedLine, cut to length and installed my power steering hoses and reservoir, hooked up my throttle cable, redid my firewall wiring and installed my new M3 covers, and installed the intake boot/mocked up where my intake will go. Productive day, I'd say. I want to fire this thing SO BAD.
