I believe Massive sold a mounting kit for the 16" SPALs.
Eta-to-M50: Build thread
Does the core support receive much stress? I was planning on doing the same thing to make some clearance for my fan, but I was a little worried about removing that seam since it would lose some rigidity and possibly split. Did you seam weld it since there are no longer spot welds holding those two pieces of sheet metal together?Comment
Lol the pre-made brackets are like $5 yo :)Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Then add another $6-8 for UPS Ground. And I'll get them a week from now. Or double that if I want them by the end of this week.
Oooooorrr... we have the material to make them, and I'll have them tomorrow. I anticipate them taking well under an hour.Last edited by Jand3rson; 05-17-2011, 08:58 PM.Comment
Brackets? sshhhhiiiiiiiittt you're getting all fancy! Mine is zip-tied to the core support in like 4 places.Comment
Alright, you guys wanted fan brackets, we made fan brackets. Took about 2 hours.
No more crappy zip ties. And on top that, the new wiring connector to the oil pan sensor is finished, all new wires and ground ran back up to the main harness. Radiator is mounted, Andrew is wiring up the fan tomorrow after work, and in the meantime, I will re-wrap the lower harness and put everything under and including the intake manifold back together.Comment
