Eta-to-M50: Build thread
Originally posted by Wh33lhopVANOS: sometimes you just need to go full retard.Comment
Originally posted by stewie30luvrooo cause i was fixing my chain tensioner and there was a black widow on the radiator so i killed itOriginally posted by JakePwith a coathangerComment
Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
If you haven't seen it, you should check out my build thread. Lots of fun stuff going on in there.
/threadjackComment
The quality of Andrew's work is great, I have A LOT of custom fab work on my car that either he has done for me, or we've done together.Comment
So, I just went out and tried to start the car, no dice. What is does is just cranks very slowly (not fast like it's trying to start), with a RRRRRR-RRRRRR-RRRRRR-RRRRRR sound.
I pulled the fuel supply line off the front of the rail, and no fuel in the line or dripping out of the rail. Also pulled the return off under the manifold, no fuel dripping out and no fuel when I turned the key, so the lines aren't reversed. Not sure what else to check.
Could I be totally out of gas, and would that cause this? I know it was very low when I parked it, I drove it around to almost empty intentionally, and the fuel light IS on. Forgive me sounding like a complete tard with questions like this.Comment
I put it on the charger this morning, dial indicator was at about half, maybe I didn't leave it on long enough. It sat for about 2 weeks. It definitely sounds like a car would when the battery isn't charged enough, but wouldn't it still be getting fuel?Comment
