Yoshi's build thread S52 on 1 bar... kinda
  • ahriley91
    • Jan 2010
    • 451
    Originally posted by shiboujin
    I just have to wire a separate breakout box with the bip373s and some 330ohm resistors. It shouldn't be so bad. I did it with my MS1. Except this time it'll be firing them sequentially.
    So are they inline from the coil itself to the msx? And I've heard that with the MS3 and MS3x that you do not need the 330ohm resistors.
    http://www.r3vlimited.com/board/showthread.php?t=162444
    • funcrew
      • Jun 2007
      • 1223
      Forgive my ignorance, but are you controlling vanos with the MS3? Or can you use a non-vanos head on the S52 block?
      "If the sky were to fall tomorrow, the tall would die first."
      -Dr. Paul Forrester
      Do I LOOK like I need a psychological evaluation???
      • ahriley91
        • Jan 2010
        • 451
        You can control the vanos with the expansion for MS3. It has an output for variable valve timing. Which is simple for the m50, m52, s50, and s52 because the vanos is just an on and off type, black and white. But the m52tu and engines after that have double vanos and are variable.
        • shiboujin
          • Feb 2006
          • 2791
          The circuit DIY gave me was the 330 ohm one. It should be the same as the MS1. Only difference is that I'm running them sequentially. IE 6 wires in, 6 wires out. That's it.
          I'm running a worked non vanos head. MS1 can do vanos as a nos output. MS3 can do full VVT but I'm unsure of specifics.
          • ahriley91
            • Jan 2010
            • 451
            I've heard that you do not need to run the 6 330ohm resistors with the bip373's.
            • Winning
              • 39
              Subscribed!
              • shiboujin
                • Feb 2006
                • 2791
                bip373s are direct drop ins for the vb291s. Still need the resistors.
                • TexasTerp
                  • Jan 2009
                  • 3541
                  congrats on the new engine build yosh!
                  stephenbrody.com
                  • ahriley91
                    • Jan 2010
                    • 451
                    But more durable according to DIYautotune.
                    • shiboujin
                      • Feb 2006
                      • 2791
                      yes. That's why they stopped using the vb291s. BIP373s shut down when they overheat instead of exploding. To my knowledge, no one has killed a BIP373
                      • whodwho
                        • Jun 2008
                        • 1547
                        But they don't have an insulated case so you do need to use a mica insulator if on a common heat sink
                        yes. That's why they stopped using the vb291s...
                        Actually they stopped using them because the vb921s are NLA ;)
                        My M20 Frankenbuild(s)
                        4 Sale - Fully Built TurnKey Megasquirt Plug and Play EMS
                        • shiboujin
                          • Feb 2006
                          • 2791
                          Ok ok. We are splitting hairs at this point >_< I didn't want this thread to turn into MS fun town. I can start another thread just for my MS3 build if people want. I'm due to start wiring whenever I finish with the temp track E30.
                          • ahriley91
                            • Jan 2010
                            • 451
                            That would be greatly appreciated. :D
                            As well as base maps...haha. Wishful thinking.
                              • 34839
                              where's the rats nest wiring harness? :p
                              lmk if you have MS3 q's. Man, I would have gone with the vanos head though, especially with MS3..
                              • QUKBMER
                                • 8178
                                Sounds like a bitchin build.
