Yoshi's build thread S52 on 1 bar... kinda
  • shiboujin
    • Feb 2006
    • 2791
    #31
    Originally posted by ahriley91
    That would be greatly appreciated. :D
    As well as base maps...haha. Wishful thinking.
    I can post the base map from my m50b25. I'll post my S52 map when I'm done but it won't help most people.
    Originally posted by nando
    where's the rats nest wiring harness? :p
    lmk if you have MS3 q's. Man, I would have gone with the vanos head though, especially with MS3..
    you actually got it working? awesome!
    Rats nest is gone. I'm using 2 starter harnesses and an E34 harness to start. I'm hopefully planning for everything from the start meow.
      • 34839
      #32
      yes, running since october.
      • ahriley91
        • Jan 2010
        • 451
        #33
        M50 would be the one that I would need! Following this build.
        http://www.r3vlimited.com/board/showthread.php?t=162444
        • yosh
          • Aug 2009
          • 350
          #34
          dude i sold your boy a single mass M20 flywheel, grab that one if he didnt use it?
          any benefit of running sequential instead of wasted spark? other than maybe keeping the temps of the bip373s down because they fire half as many times?
          • shiboujin
            • Feb 2006
            • 2791
            #35
            which boy?
            the sequential spark just extends the life of the coils and drivers. I doubt there is any other advantage.
            • LJ851
              • 7919
              #36
              Nice project! I have a single mass M20 flywheel for you. PM me.
              Lorin
              The M30 is God's engine.
              • shiboujin
                • Feb 2006
                • 2791
                #37
                already got one shipped. Thanks tho!
                Started wiring last night. lulz
                  • 34839
                  #38
                  Rats nest V2.0? ;)
                  • shiboujin
                    • Feb 2006
                    • 2791
                    #39
                    The goal is not to :) The problem with the last one was lack of knowledge and foresight. I've done about 6 or 7 MS installs on other people's cars since my original car and I've gotten pretty good at it.
                    I'm using the E30 M3 harness cover and harness holder to keep everything tidy from an outside perspective. I started with an E34 harness, cut off the DME plug and started yanking wires I don't need. I'm hunting around today for wiring diagrams for the E34 so I can keep wire colors similar. IE I'm adapting the intake temp sensor plug for the MS but I'm just going to cut off the stock IAT plug and wire this one in. That way, the wiring diagram from an E34 is relevant to me permanently.
                    I'm also trying to find a good way to adapt all my wiring for gauges so they can run parallel to the wiring instead of around it.
                      • 34839
                      #40
                      that's exactly what I did
                      the biggest issue is the E34 harness is about 6" too short. be sure you extend it a bit. you can make it work but it totally sucks, I'm going to have to pull mine out and extend it later. already have the extension built, just need the time.
                      my MS3/E34 harness chart is based off the Vanos motor if that's of any use to you
                      • shiboujin
                        • Feb 2006
                        • 2791
                        #41
                        Should be the same right? got a link to it?
                        I have 2 decent length starter harnesses from DIYAutotune.com so the length different shouldn't be that big of a deal for me. Although I am using the AC hole to push the DB37s through since I don't want to cut open the stock ECU hole.
                          • 34839
                          #42
                          Yeah unless you have an NV harness, it's a little different.
                          using the A/C hole is a pretty good idea. I fit mine through the stock hole, but just barely. Hmm, maybe I'll move it when I extend the wires..
                          • shiboujin
                            • Feb 2006
                            • 2791
                            #43
                            Aw. mine is NV. I think. Yea NV.
                            Also, how did you wire your coil drivers? External driver box? 330ohm resistors I'm assuming?
                              • 34839
                              #44
                              No coil drivers - LS2 coils. they're just a 0-5v on/off signal. extremely powerful, durable (built in overdwell protection), simple, and cheap. :)
                              but yes, you'd wire them like you would normally.
                              I've meant to do an NV chart, I just haven't gotten to it. there's still probably useful information in there for you.
                              • Overlord475
                                • Dec 2010
                                • 799
                                #45
                                You should run it on a Dino before you FI so you can see what kind of HP / TQ this crazy hodge podge M/S5x (whatever the frik you'd call this motor combo, hahah) makes.
                                --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
