The Turbo 325ix build!
thanks man, is your sig on top of that garage across from oly supply? for now its going to be my way too fast DD. im going to do a full suspension rebuild with all new bushings and a heavier sway bar in the rear for the understeer. and im looking in to doing a 5-lug/bigger brake swap.
and depending on how much i like the 4wd on the track i might get a comfy DD and just strip and cage this thing and build it for track/autox. i would feel really bad about doing that to such a fine ix.
i dont know really, a lot depends.Comment
if you want to eliminate understeer, go with stiffer springs and GC's new ix camber plates. a stiffer rear bar is likely to make things worse.Comment
Yup, that's the garage (taken about 6-7 years ago, I don't upgate my sig ;))
It'll definitely be a fast daily! If you go 5 lug, look at the E36 M3 setup for brakes. Seem to be a good value for the cost. The E30 brakes always leave me wanting more...Chris
90 Corrado/91 M3/01 M5
hmm alright ill look at that. i read that the sway bar was the fix from these ix guys in colorado, but i could really use camber plates.Comment
Love this project! Wish I would've known more about using a standard M20 block instead of searching high and low for an iX one. Suscribed!clutchCTRL!Move with a purpose.- 1991 325iX 4dr/5spd- 1976 2002 SlickTop/2.7i M20/G260- 2000 323i AT2016 Mazda CX3 Sport AWDComment
Update 4/8/11
Okay, after i discovered my oil pump error thanks to nando, i took today to swap my intermediate shafts since the ix pump runs in reverse of the rwd pumps.
it wasnt too difficult after i figured out a way to remove my crank bolt. i was patient and very careful.
ill give little how to here for others to reference.
-remove distributor, upper timing belt cover (8mm,10mm,13mm bolts)
-remove the six bolts that sandwich the vibration damper (13mm)
-remove the crank bolt (22mm) this easy if you have an impacter, but i dont. i took two fly wheel bolts and wedged a bar of 1"x3/16 steel and braced it with a bolt for mounting the engine to a stand. stood over the engine with a breaker bar and pulled as hard as i possibly could. success.
-next remove the lower timing belt cover and pop off the vibe damper and anything else(10mm) at this point i loosened my belt and removed it
-remove the pulley that drives the intermediate shaft. (15mm)
-in order to remove the shafts retaining plate you have to remove that shroud thing that houses the front main seal. to do that you need a specialty tool to pull the pulley off the crank. yet again, I DO NOT HAVE! so i fab. i took a chunk of the 1"x3/16" bar and drilled holes to fit the ~1.5" extra bolts with the same thread as the six we just removed. i threw a socket in there as a shim and placed the plate i just made over it and threaded my bolts. as you tighten it pulls the gear. it may be required to repeat this process and add more shim height.
-now undo the 10mm and 13mm bolts that retain the shroud. remove shroud thing
-you will now see the retaining plate by the intermediate shaft. i used my power drill and CAREFULLY removed the two flat head screws.
-remove the 13mm bolt that retains the aluminum plug where the old carb'd m20 distributor goes. rotate the shaft and pull to remove the drive gear. then the shaft will slide right out!
HELL YA im very proud.
My ix intermediate shaft had a hand engraved "25" on it. any one know whats up with that?
the mess
thats all for tonight. tomorrow ill remove the strokers shaft and finish the swap. im also picking up some grey e36 m3 seats tomorrow for $150. non vader :( i may not end up using them and if so ill just flip them.
Update 4/14/11
Hey guys, dont have much to update you all on but basically ive been trying to get my crank bolt off of the motor i have installed so i can finish swapping my intermediate shaft. i have it in 5th gear with the brakes on but since the clutch is brand new i can actually slip it with my breaker bar....yeah flexin. actually bent one of my breaker bars. i figured id get creative and wedge my bar on the frame and turn the motor over with the starter. but the starter is too week. WTF! im going to rent an impacter.
In even MORE frustrating news: my miller war chip came the other day but absolutely wont work. the installation wizard wont open even though i just downloaded java and have good internet. again, WTF! the usb port recognizes it as a removable storage device but no WIZARD! im going to call Brody today and get some help. im really hoping i dont have to send it back and lose all of this time.
also, got some non vader e36 M3 seats that are grey. the drivers bolster has a small hole in it but i figured they beat uncomfortable plastic seats for the time being.Comment
Update 4/18/11
So without going into much detail, i pretty much finished it today.
ill have a short vid up soon. it fired right up and ran pretty damn good with the 30lb injectors. i still have cosmetic stuff like valence and such.
all was perfect until BOOM: http://www.r3vlimited.com/board/showthread.php?t=205382
here are some pics as im finishing it up today and over the last few days.
m3 seats! and keg! woot.
my boss says: puddy n paint'll make it what it ain't.
Turbo sounds so epicส็็็็็็็็็็็็็็็็็็็็็็็็็Originally posted by blunttechI need you to exfoliate my ballsack
i was really surprised with the sound myself. for a POS bov im not complainingComment
very nice. So is it the stock MAF?318iS Track Rat :nice: www.drive4corners.com
No one makes this car anymore. The government won't allow them, normal people won't buy them. So it's up to us: the freaks, the weirdos, the informed. To buy them, to appreciate them, and most importantly, to drive them.Comment
