M20B29 w/ Triple Webers into my '71 2002
  • AceAndrew777
    • Feb 2022
    • 93
    #511
    Originally posted by Sh3rpak!ng
    sheesh
    Just thankful my parts worked, haha.
    Your wiring is awesome. That's my next and last major project, other than trim bits. Therefore I'm taking a lot of inspiration to how organized your setup is (any excuse to use Kapton Tape), will be asking you some questions.
    The car is now back home.
    -E30 driveshaft measurement finalized and sent off for shortening/rebuild.
    -Using left over titanium tubing for coolant overflow tank and catch can, extra hardware inbound.
    • AceAndrew777
      • Feb 2022
      • 93
      #512
      Something quick.
      Another excuse to implement a little astro/aero manufacturing goodness into the car. This is alodine/chemfilm/bonderite, it's a chemical conversion process used when the aluminum/titanium piece is too big to be anodized or has clearance tolerances tighter than what can be done through anodizing.
      Not typically used on castings, but I had two hours this weekend and wanted to give it a go. Leaves a neat slightly-iridescent gold finish (unless you leave it in the bath too long, then it's a pasty dark yellow). Not the strongest corrosion resistance, but far better than nothing.
      Surface prep is key, anything but a water break free finish will result in blotches.
      Also, this stuff is toxic and not to be taken lightly. Handle with care and have proper storage planned ahead of time.
      EDIT: Thank you to Shant/Bimmerheads for the chopped 200 head so I could use it for mocking things up.
      IMG-3760 by Adams Autosport, on Flickr
      IMG-3761 by Adams Autosport, on Flickr
      IMG-3763 by Adams Autosport, on Flickr
      IMG-3767 by Adams Autosport, on Flickr
      IMG-3765 by Adams Autosport, on Flickr
      • kronus
        • Apr 2008
        • 13005
        #513
        reminds me of M12 cylinder heads.
        cars beep boop
        • AceAndrew777
          • Feb 2022
          • 93
          #514
          You know, I've wondered that as well. Would be interesting to know for sure.
          In the interest of another little father/son(s) project, I had my older two boys help design/make a little mounting bracket for the Vibrant vacuum manifold. Straight forward project, so perfect learning opportunity for them. Used the alodine again. Here you can see the difference in finish on a cast vs/ machined surface.
          IMG-3797 by Adams Autosport, on Flickr
          IMG-3798 by Adams Autosport, on Flickr
          IMG-3804 by Adams Autosport, on Flickr
          IMG-3808 by Adams Autosport, on Flickr
          • AceAndrew777
            • Feb 2022
            • 93
            #515
            Manifold now plumbed.
            IMG-3825 by Adams Autosport, on Flickr
            Finished adapting the Lokar throttle cable to the Redline under-carb cam bracket (drilled tapped the bracket, then made a larger cable stop barrel w/ set screw). Test fit on the car, shortened the cable as a result. Surprised at how short it ended up.
            IMG_3949 by Adams Autosport, on Flickr
            Next up was getting the wiper assembly together. The wiper motor was torn down and cleaned up, finishing it off with plated hardware and the "oh so OEM correct" blue tape. Found these cool original-style wipers to match.
            IMG_3979 by Adams Autosport, on Flickr
            Converted the electrical connection to a deutsch connector.
            IMG_3983 by Adams Autosport, on Flickr
            All in. Bizarrely, early 02's didn't incorporate any sealing around the wiper posts. I went ahead and used some rubber washers to fix that design flaw.
            IMG_3984 by Adams Autosport, on Flickr
            Next I knocked out the AN lines for the oil cooler. Yes, the bracket was stripped of it's bright-dip finish and dunked in Alodine to match.
            IMG_3987 by Adams Autosport, on Flickr
            Love these low-profile Setrab swivel fittings. Because of them, the lines and cooler can all fit below where the shroud cover will sit.
            IMG_3986 by Adams Autosport, on Flickr
            • Panici
              • Dec 2009
              • 2316
              #516
              Looking good as always!
              Steady progress towards getting it back together.
              '87 BMW E30 325is Turbo
              '99 BMW E36 M3 - - - '98 BMW E36 328i
              • moatilliatta
                • 6121
                #517
                Did you cut a hole in the inner fender for air flow thru the oil cooler?
                @Zakspeed_US
                • AceAndrew777
                  • Feb 2022
                  • 93
                  #518
                  Yes, here's a shot when I was still in bodywork phase.
                  IMG_8336 by Adams Autosport, on Flickr
                  • moatilliatta
                    • 6121
                    #519
                    Noice.
                    Does the back side have a protective screen?
                    @Zakspeed_US
                    • AceAndrew777
                      • Feb 2022
                      • 93
                      #520
                      Noice.
                      Great point, not yet. I intend to make a screen before running it though. Looking around for a simple screen material, if you have any suggestions I'd be all ears.
                      Vapor blasted some parts yesterday (was able to use one from a local shop, very grateful), going to try and have a friend use clear cerakote over top.
                      • moatilliatta
                        • 6121
                        #521
                        Our wire mesh is woven from stainless steel wire. You can cut it with tin snips and shape it as you would sheet metal. Use it to protect radiators and oil coolers against small rocks and other debris.
                        I know you can get Black aluminum mesh off amazon. Slats would be nice to keep water out.
                        @Zakspeed_US
                        • MasukBMW
                          • Sep 2006
                          • 324
                          #522
                          Dang wanted to go back thru this (again) - are the older pics lost forever?
                          • AceAndrew777
                            • Feb 2022
                            • 93
                            #523
                            Working on more updates right now,
                            -shifter platform and lever.
                            -redoing seats w/ new leather weave.
                            -electrical (PDM?).
                            A lot of the older ones are lost, thanks to the photobucket fiasco. However, I did reupload a bunch of them to flickr....
                            https://flickr.com/photos/152898763@...th/36948752596
                            • AceAndrew777
                              • Feb 2022
                              • 93
                              #524
                              Painted the uprights and the areas behind the headlight brackets black, this was done to differing degrees on 2002's from the factory (pet peeve on repainted cars is to see the body-color uprights blaring from behind the grills. I also painted the front portion of the aluminum radiator with Eastwood’s radiator paint.
                              Test fit the front grill to make nothing visually jumps out from behind. Fun fact, I bought the grill in 2012 when BMW did a batch of them. Price was $107. Glad to finally see it on the car.
                              IMG_0099 by Adams Autosport, on Flickr
                              Got the header back from ceramic coating from the boys at Raw Powdercoating (LongBeach). They do fantastic work, enthusiast owned/operated.
                              IMG_0101 by Adams Autosport, on Flickr
                              Thanks to Jesus at CK for the E9 3.0cs OE spark plug wire loom, another little period touch. It was mounted with some standoffs to clear the headers, but will likely need some thermal protection for the wires.
                              IMG_0102 by Adams Autosport, on Flickr
                              As a bit of a change of pace, I wanted to learn how to do wood refinishing. To that end I picked up this NK shift knob that needed some love.
                              BMW_2002_Shift_Knob_ADAMS_02_BEFORE01 by Adams Autosport, on Flickr
                              My improvised "lathe". Sanded it down, then sanded it back up to 1000 grit, light stained to match the Nardi, and then used the CA-glue method to coat it (and the emblem) with several layers. Very happy with how it turned out.
                              BMW_2002_Shift_Knob_ADAMS_03 by Adams Autosport, on Flickr
                              BMW_2002_Shift_Knob_ADAMS_02 by Adams Autosport, on Flickr
                              ….. and it’s finals week! First final is tomorrow morning.
                              • Panici
                                • Dec 2009
                                • 2316
                                #525
                                Car looking great!
                                Down to the little touches now that make all the difference.
                                Good luck in the finals.
