plans for a full exh mani or stock manifolds with up pipes?
thats actually a great question..u said revshift but they have a few different types. The cheapest is using the stock manifolds...obx also offers one like this.
then theres the one that gets rid of all the stock manifold, the $749 one which reminds me of one on amazon for 279..if i could hand fab a manifold it would probably be like this.
and THEN revshift has a twin scroll manifold, $1099 for that. what makes a twin scroll manifold/turbo set up so much better?
Im going to be building up my turbo this winter so i am very interested in all these turbo builds popping up.
Project looks good 2. I need to learn how to take my motor apart!lol
Since your turbo has a divided entry a twin scroll manifold is divided as well. 3 cylinders into one bank and 3 cylinders into another bank. It splits the exhaust pulses (hence the name "split pulse manifold") and improves your spool time immensely. A proper twinscroll manifold/ turbo setup will give you spools under 2500 rpm all day.
I'd really recommend a high quality manifold. the one that is forsale on amazon is the same as the ebay ones and are made from thin wall steel that is prone to cracking after several hundred heat cycles. I've also read a few people saying that they needed to drill out some of the bolt holes to make it fit.
Personally i think the revshift twin scroll adapter is the cats pajamas because it's cheap and still provides you with the split pulse entry. but nothing beats a full scale twin scroll manifold with two 44mm wastegates
Nice ass build so far though man, this thing is gonna haul ass!
It's in and it's alive!
List of things done during this swap:
2.7l stroker with metric mechanic head
5 speed getrag 260 swap from auto
89' wiring harness
Megasquirt PnP setup
E36 m3 steering rack swap
Eibach sway bar installed
Custom hose routing with late model coolant tank
More I can't remember
where did u have the block resurfaced and all that. i need to ship mine out while I have surgery. and did u send your intake manifold also? it looks like u can eat some cheese cake off it!haha (im enjoying some right now)
I cant wait to turbo my m20. u have raised the bar my friend. lets see a video of it
thanks for sharing man! I no longer plan to cheap out on the manifold. ive been reading and i need something better for sure. ill look into revshift again
I had the block done at a local engine shop I'll try and find the name. I'm still working on dialing in the n/a tune and fabbing the 3"exhaust, then I'll put the turbo on. I was really considering tapping the block but it would have been my first time attempting and I didn't want to damage the most important part so I opted for the pan instead, seems to work okay. Thanks guys!
