In July I picked up what was supposed to be an 87 eta that just needed a couple weekends of wrenching and tuning and maybe some paint to be a decent daily driver. I built an e30 for LeMons a couple years ago and have since accumulated a pile of parts and know-how so it seemed to make sense. At that time all I knew was it came from Hawaii (was rust free), it’s inspection sticker was 4 years old and it had a horrible re-paint job.
As I began working on it I discovered it was clearly a food victim and the PO drove it like a Camry, just oil, fuel and necessary repairs. Someone even replaced the fuel filter with a straight piece of fuel line. Carfax reported it being registered in Florida. Because it wasn’t rotten and the engine had good compression I decided to just give it a mechanical overhaul and catch it up on preventative maintenance.
So, here is my list of things I have done:
Engine:
Steering and Suspension:
Driveline:
Brakes:
Things I’m still working on (because I am having problems with them):
I’m not going to start getting into exhaust or cosmetics until the car feels mechanically sound. My first question, are there any glaring omissions from the list above?
Engine:
- Fresh oil and filter
- Air filter
- Timing belt & tensioner
- Water pump
- Upper cam seal
- Thermostat
- Valve cover seal and plugs
- Spark plugs, wires, cap and rotor
- Coolant hoses
- Fresh coolant
- AC, Alternator and PS drive belts
- Replaced all fuses
- New external fuel pump and filter, and hard lines
- Front control arms, endlinks, and tie rods
- Rear endlinks
- Rear shock mounts
- PS fluid flush
Driveline:
- Complete shifter linkage rebuild, z3 1.9 lever and delrin bushings
- Transmission mounts
- Transmission oil change
- 3.25 LS diff, painted, resealed and filled with fresh fluid
- Driveshaft guibo and center bearing
Brakes:
- All new brakes, rotors and parking brake shoes
- All new rear brakelines from the tee back
- All new soft lines
- Steering joint with IE poly guibo
- Flushing brake lines/calipers with new fluid
- In-tank fuel pump
