Kamotors E30-Turbo to ITB M20
  • LowR3V'in
    • 4209
    #2131
    Vent the tank to atmosphere.
    Let the hose down under the car somewhere.
    Also I think I used an m20 slave and an m10 as well because it was aluminum.
    tcd stg3 feels almost stock try that out it'll do 500tq.
    • kamotors
      • Nov 2007
      • 7102
      #2132
      thats how its like, it goes to charcoal canister then that vents to under the vehicle. The tank is getting very hot, fuel pump starts whining and it starts puking. If I open the gas cap I get massive hot fumes pouring out, if I close the cap and wait 1minute I can repeat until the tank cools. My exhaust is like 2 feet away from the tank but I'm guessing at freeway speeds its just blowing right into the tank or something.
      7speedshop.com
      • efficient
        • Feb 2012
        • 3312
        #2133
        Swap the m20 back and call it a day lol
        • kamotors
          • Nov 2007
          • 7102
          #2134
          i know lol^
          7speedshop.com
          • Bullet Ride
            • Dec 2010
            • 598
            #2135
            Isn't there a check valve on the line that goes from the intake manifold to the canister? If that fails is it possible to somehow pressurize the gas tank with boost?
            • RagtopE30
              • Dec 2010
              • 1869
              #2136
              I am glad I already did my swap because reading about how yours is kicking your butt I may have never done mine! Lol
              450whp 524 lb-ft 1988 336ic In progress
              http://www.r3vlimited.com/board/showthread.php?t=250709
              • LowR3V'in
                • 4209
                #2137
                Na, his stuff is unique I've never even read about stuff he's posting about because of
                using an m30.
                • kamotors
                  • Nov 2007
                  • 7102
                  #2138
                  removed the check valve when I did the swap, gas tank is vented to atmosphere(always has been for me) but issue just started, pretty sure megasquirt cant control that check valve anyway
                  7speedshop.com
                  • FLG
                    • Sep 2011
                    • 3165
                    #2139
                    My exhaust is quite close to my tank and I've never had an issue.
                    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                    • kamotors
                      • Nov 2007
                      • 7102
                      #2140
                      well even more annoyed now, Pulled the trans this morning and everything looks prefect, disk installed correctly(its physically impossible to install backwards), flywheels, pressure plate all look normal.
                      The only thing I can think of is maybe the OEM clutch fork arms is bad as the Throw out bearing does not snap in tight its a pretty loose fit. I have an MTC clutch fork lever and the TOB snaps in very tight actually.
                      Is it possible during installation my TOB rotated 90degrees? which make it sit in further and would seem to cause this issue.
                      I have no clue why it wasn't working when it was all installed 100% correct.
                      7speedshop.com
                      • kamotors
                        • Nov 2007
                        • 7102
                        #2141
                        found the problem. Clutch disk seems to be very warped.
                        7speedshop.com
                        • kamotors
                          • Nov 2007
                          • 7102
                          #2142
                          video of how bad its warped.
                          7speedshop.com
                          • ForcedFirebird
                            • Feb 2007
                            • 8300
                            #2143
                            Originally posted by ForcedFirebird
                            You probably can get it in gear with a blip because you are rev matching, not because the clutch is slipping - this is how you shift in an endurance race when the clutch hydraulics give way.
                            I have run into your same issue several times on various BMW's (from stock to swapped to mismatched parts), and had to remove the trans in all situations. Most of the time it's a customer that changed the clutch themselves and we had to figure out what went wrong. If you have to increase the idle to get it to slip, there's definitely something wrong.
                            Clutch disk bent
                            Clutch disk backwards
                            Shift fork slightly bent
                            Incorrect disk size for flywheel (he had a 328 someone swapped a Getrag in, ordered a 328 clutch kit)
                            Worn pivot ball
                            Wrong slave
                            You might be able to extend the slave rod a little and band-aid the problem, but if you go too far, the fork will rub the rivets in the pressure plate. The rod just pulls out of the slave, weld some material on the end.
                            The problem "may" go away with wear, but the clutch doesn't lose much thickness when it is considered worn, and will significantly decrease the life of your clutch.
                            That's the number one culprit in my experience, and why it's first on the list.
                            john@m20guru.com
                            Links:
                            • kamotors
                              • Nov 2007
                              • 7102
                              #2144
                              well I'm happy Its something somewhat simple, and thanks for the help!
                              I got the driveshaft, exhaust and trans pulled in under 3 hours!
                              But for those of you in positin 2 and 3 its nearly impossible to remove the upper most bellhousing bolt on the M30 swap as it sits in the firewall ABOVE teh trans tunnel I had to put a jack between the trans tunnel and trans to pry the trans down and remove that bolt, HUGE PAIN. will be denting up the tunnel before that goes back in.
                              7speedshop.com
                              • kamotors
                                • Nov 2007
                                • 7102
                                #2145
                                can I keep the flywheel as is? or does it already need a resurface with less than 300miles on it?
                                [IMG]IMG_1229 by kamotors@y, on Flickr[/IMG]
                                7speedshop.com
